Old 23-02-2007, 03:53 AM   #1 (permalink)
Default remote desktop conx
Hi,
Can any1 who have already used remote desktop conx to establish the same to a computer which is not in the network tell me how to do it. I have to connect to my system back at India. I have searched to some extent using google but cudnt find any detailed instructions... it wud be helpful if any1 can direct to a link even!
thks a lot,
legolas.
legolas is offline
Old 23-02-2007, 06:32 AM   #2 (permalink)
HELP AND SUPPORT
rakeshishere's Avatar
Default Re: remote desktop conx
Install Symantec PC Anywhere,and Use the internet ip address for RDC
rakeshishere is offline
Old 23-02-2007, 08:13 AM   #3 (permalink)
Great. Thanks a lot. wil try that. but i wud like to know abt this "remote desktop conx" too, just in case any1 knows!
thks
legolas.
legolas is offline
Old 23-02-2007, 11:06 AM   #4 (permalink)
HELP AND SUPPORT
thks
legolas.
http://en.wikipedia.org/wiki/Remote_Desktop_Protocol
RDC-->http://www.google.co.in/search?hl=en...nnection&meta=
Old 23-02-2007, 12:35 PM   #5 (permalink)
Livin' in the ghetto
AshishSharma's Avatar
U need a dedicacted Public IP for the actual RDP to work, which obviously isn't cheap... So U have other options like the Symantec PC Anywhere mentioned by Rakeshishere or u may launch VNC server on your machine and connect it as a VNC client ...
~.~ Never argue with idiots, they just drag you down to their level then beat you with experience. ~.~
AshishSharma is offline
- by Piyush
