Originally Posted by jigar657
if anyone has used winfax...
may i know how long does it normally take to send the fax thru my modem...i mean is it faster than regular fax machine...
plz guys reply soon...
jigar
Actually, what all fax programs do is make a virtual printer driver. Then you print to that fax-printer and it will invoke the faxing software. So that way you can fax from all applications.
Time taken is almost similar. I haven't seen any great increase or reduction in speed while sending. However, receiving is a little inconvenient, although its almost the same speed.
Speed depends not only your machine, but also the machine at the other end. Usually, modems are faster than fax machines, but the actual speed is the speed of the slower device.
