Old 25-01-2005, 07:10 AM   #1 (permalink)
Default Disappearing quick launch bar
Every time i log off,the quick launch bar disappears...i have to manually make it active(rt click taskbar>toolbars>quicklaunch)..this has statrted happening suddenly for last few days...how do i make it stay?plz help.
a ship is safest at the harbour but thats not what its built for!
serendipiti is offline
Old 25-01-2005, 03:59 PM   #2 (permalink)
Šupər♂ - 超人
koolbluez's Avatar
me 2 got da same problem b4...
Someone please help... need the real cause of it...
koolbluez is offline
Old 25-01-2005, 07:02 PM   #3 (permalink)
Web Entrepreneur
ShekharPalash's Avatar
Everytime??
Strange!!
Looks like some bug/virus...
Can u plz post ur Hijack This Logfile...
Do this... Expand QuickLaunch in taskbar-righ-click-open folder...
this will open it's folder...
Lokk for contenst there...
delete all you don't want except, IE/Firefox, Desklink and WMP
also check the properties of tht folder... if "hidden" is grayed out then try to Customize>ChangeIcon> Restore Default...
This will restore Quick Launch's properties...
Also check your start-up options, may be some spyware... better post your HJThis Log...
Live Chat with Doctors 24x7 on my site http://healthcaremagic.com
ShekharPalash is offline
Old 26-01-2005, 07:12 AM   #4 (permalink)
Default prob solved,thanx
thanx for ur replies mates...seems like a virus/spyware was the culprit...surprisingly NAV 2005 detected the threat wherein Ad-Aware,Spybot S n D and Microsoft Anti Spyware all failed to do so!
- by Piyush
