Old 21-02-2007, 08:23 PM   #1 (permalink)
jobenjoseph
Posts: n/a
Unhappy help
hi guys,
i know this question has been asked maybe a zillion times but due to rapid increasing technology old ones become extinct so
could somebody tell me :
1) which is better a company built gaming machine or an assembled one?
2) if company one which one is the best and if assembled what would the specs be??
i am a huge fan of counterstrike online play as well as FPS and RTS games so what specs would i need?? ( i plan to buy a computer dedicated to gaming only)
so fellow bros do help moi!!! : )
Old 21-02-2007, 08:32 PM   #2 (permalink)
Tech Geek's Avatar
Default Re: help
It depends on your budget tooo.
tell us the budget
Tech Geek is offline
Old 21-02-2007, 08:34 PM   #3 (permalink)
Google Bot
Pathik's Avatar
Default Re: help
get a assembled pc...
btw tell us ur max budget so that we can give u a appropriate config...
Pathik is offline
Old 21-02-2007, 09:06 PM   #4 (permalink)
ApoorvKhatreja's Avatar
Default Re: help
Always go for an assembled PC only if you know somebody who can guide you, and get you quality parts for reasonable rates. If you yourself step into the market to buy parts, you are sure to be cheated. If you want a PC for gaming, go for assembled, with highest quality parts, and good configuration. If you buy a company PC with the same specifications, it'll cost you much more. For simple office work always a company PC is advised, due to good after sale services, and company guarantee.
http://apoorvkhatreja.blogspot.com
ApoorvKhatreja is offline
Old 21-02-2007, 09:15 PM   #5 (permalink)
Debian Rocks!
freebird's Avatar
Smile Re: help
if u r 4m kerala,i suppose get urself a good reliable assembler and PC components acc to yor needs from wholesellers like Online,Noveon,aldous glare exp or IMC in ernakulam or ozone sys in Kotyam.these are companies-they afaik dont cheat as there is no kms long shops for pc parts in cochin as is in mumbai or Madras.another soltn is to go for orchid branded pc-which sure allows u to have custom configs.
http://www.teamfrontline.com/orchid.htm
"The day windows users wake up to reality, it will be doomsday for Microsoft."UNIX like OS are more secure.get urself out 4m M$ http://whylinuxisbetter.net http://tinyurl.com/2amjjc http://fsf.org
freebird is offline
Old 22-02-2007, 08:19 PM   #6 (permalink)
jobenjoseph
Posts: n/a
Default Re: help
hi less than 50,000 is moi budget : )
Old 22-02-2007, 08:40 PM   #7 (permalink)
Google Bot
Pathik's Avatar
Default Re: help
Core2Duo E6400
Intel DG965RY
BIG Nvidia 7600 GT 256MB PCI-E
2*1GB Transcend DDR2 Ram
Sony DRU-830A
Seagate 400GB SATAII
VIP case + 500 watts SMPS
Creative 5.1 speakers
Samsung 17" CRT
Pathik is offline
Old 22-02-2007, 08:41 PM   #8 (permalink)
Tech Geek's Avatar
Default Re: help
The total will be about 35K-40K
Old 22-02-2007, 08:52 PM   #9 (permalink)
Alive Again...
satyamy's Avatar
Default Re: help
Go for Assebmled
You can get a Cool Gaming PC in around 40K
the config told by pathiks is good go fo 17" Flat CRT Monitors, also u can buy any gaming device u like.
satyamy is offline
Old 23-02-2007, 01:09 AM   #10 (permalink)
Default Re: help
The creative 5.1 speakers are not suited to gaming - The Creative GigaWorks S750 are much more suitable for gaming purposes. Here are some other models.
http://www.nextag.com/gaming-speakers/search-html
Old 23-02-2007, 01:40 AM   #11 (permalink)
caleb's Avatar
Default Re: help
Go with the config given by pathiks ...the only change I made is the HDD bcoz of ur budget...anyway here are the prices for those components:
Core2Duo E6400 = Rs.11500/-
Intel DG965RY = Rs.6400/-
BIG Nvidia 7600 GT 256MB PCI-E = Rs.8200/-
2*1GB Transcend DDR2 Ram = Rs.7200/-
Sony DRU-830A = Rs.1900/-
Seagate 250GB SATAII = Rs.3800/-
VIP case = Rs.1500/-
Powersafe 500 watts SMPS = Rs.2000/-
Creative 580SBS speakers = Rs.3000/-
Samsung 17" CRT = Rs.4500/-
PS. I suggest you hold off on buyig the Graphics card till April as the budget DX10 compatible cards will be available sometime in April.
caleb is offline
Old 23-02-2007, 12:26 PM   #12 (permalink)
jobenjoseph
Posts: n/a
Wink Re: help
thanks a million guyz big help : )
- by Piyush
