There are some programmes in which hilighting the tray icon gives options to hide the icon from the tray.How can I do the same thing with any tray icon?
Windows 7 Ultimate,Intel Core 2 Duo E 7300,3 GB Ram,ATI Radeon HD 4850 graphics card.
Well There are Tons Of Utility For It.....The One That I Use is Ps Tray.....It Would only Hide The Icons in The System Tray But Will Be Visible In The Ctrl+Alt+Del Menu
Get It From Here www.soft32.com/download_1647.html
