Old 25-01-2005, 01:44 AM   #1 (permalink)
Default MS Visual Studio .NET && C# ???
I don't have MS Visual Studio .NET , but I want to work on C# ....... is it possible without installing the former? Also, ASP.NET !!!
Shine on ! You crazy diamond !!!
pag_floyd is offline
Old 25-01-2005, 01:31 PM   #2 (permalink)
install .net framework.. free download.. or available on digit cds
open notepad.. write c# programs.. save text file with <filename.cs> extension
open command prompt.. travese to the dir where u saved the file
type
cs <filename>
mind u i thnk it only works for console based applications
Attack life, it\'s going to kill you anyway.
walking-techie is offline
Old 25-01-2005, 04:22 PM   #3 (permalink)
try the free open source IDE SharpDevelop
it is a free IDE for C# and VB.NET projects on Microsoft's .NET platform.
check it from following url
http://www.icsharpcode.net/OpenSource/SD/
Sudhir Mangla
http://DevelopersVoice.com
(VC++ FAQ, MFC FAQ, C++ FAQ)
http://Programmerworld.net
(Free books and source code)
sudhir_mangla is offline
Old 26-01-2005, 03:20 PM   #4 (permalink)
thanks a lot......... I have Windows XP Home...... I came to know that HOME doesn't support some fetures of .NET.... what all r they??
Old 31-01-2005, 12:26 PM   #5 (permalink)
Most of them would be related to ASP.NET.
According to MSDN
Visual Studio .NET 2003 does not support creating ASP.NET Web applications or ASP.NET XML Web services when using Windows XP Home Edition.
Sudhir Mangla
- by Piyush
