Re: stuck with a strange prob
Well taskkill is not the best way to close any app ..try nd toubleshoot the Task Scheduler issue instead, here are some basic must check :
Make sure Event Log Service is set to automatic and running.
Click the Log On tab, select the Local System Account and Allow Service to Interact with Desktop options, and then click Apply.
Make sure that the Read-nly attribute is not set on the Schedlog.txt file in the %SystemRoot% folder.
~.~ Never argue with idiots, they just drag you down to their level then beat you with experience. ~.~
