Old 24-01-2005, 10:15 PM   #1 (permalink)
Default how to make CD images
hi
can anyone tell me how i can make CD images which can be mounted on a image drive?
i have Nero 6 ultra edition suit.
please help me!
i would be higly oblidged.
ayush456 is offline
Old 25-01-2005, 12:17 AM   #2 (permalink)
hmmm
use the copy cd option
choose ur recorder as image drive first
this will save ur image to the HDD
ofcourse it'll be in NRG format
alternatviely u can get ultraISO and select ur cd drive ( yeah all of it ... the whole drive letter from the lower left pane ... after inserting ur cd ofcourse )
and drop it to the upper main pane
and click create image
then choose what image format u wanna save it as
and wait till its done
No Mercy, No Limits.
theraven is offline
Old 25-01-2005, 11:23 AM   #3 (permalink)
Default Use Alchohol
Alchohol 120% is the best softawre for making and writing images.
Sometimes its helped me to copy some scratched CD's to my HDD.
Go for it.
Kapil Wadhwa
hikapil@yahoo.com
http://www.flashwires.com
hikapil is offline
Old 25-01-2005, 03:37 PM   #4 (permalink)
Šupər♂ - 超人
koolbluez's Avatar
Make images with Alcohol 120... IT ROCKS
Esp. VideoCDs can b saved efficiently.. with min. bad sectors... also nice customized options
U can also make images with Nero... but i personally seldom use it.
Search in Nero's windows for "Image recorder" option & make image, as Spambot theraven said... simple.
AND BETTER USE NERO EXPRESS
koolbluez is offline
Old 27-01-2005, 02:01 PM   #5 (permalink)
Yoda's Avatar
Use UltraISO. Its very easy to make.
Insert the CD then use the software to make the CD image and use can choose various options about how your image file be created.
Yoda is offline
Old 30-01-2005, 12:32 AM   #6 (permalink)
Default cd image
dude if u want to know about cd image through nero 6.0 :------
before clicking it will show the popdown destination as cd r/wr or as the cd image jst click over that and select the cd image provide the path to it
zuhaib is offline
Old 04-03-2005, 02:55 PM   #7 (permalink)
be4 proceeding with what zuhaib has said,u shld install nero image drive.I guess nero 6 supports 2 image drives - cd and dvd .
once the image file is created,mounting is easy,right click on image file,select image drive.
voila! ur cd is loaded.U also hav an eject option to unmount the image.
C2D@ 2.4Ghz,Asus P5B Dlx,2X1GB Kingston@677 Mhz,Viewsonic 20",Sparkle 7200 GS ,SB Live Audigy on Creative Inspire T7900,Leadtek WinFast XP TV Tuner,Storage :Seagate 320GB + WD My Notebook 1TB
blacklight is offline
Old 04-03-2005, 05:49 PM   #8 (permalink)
Just Do It
Nero Image drive program is gud......
The Nero ImageDrive program creates an extra drive
letter in your Windows Explorer. It usually takes the very first drive letter after your hard drives and before any other CD-ROM or other removable drive.
Once installed, go to your control panel and launch the Nero ImageDrive program. Select a Nero/Nero Express data image file with the extension of NRG and it will mount this image file in your Windows Explorer under the extra drive letter.
Once mounted, you can treat this image as if it was a normal CD: You can read its data, copy data from it to your hard drive or launch a program from it.
Charley is offline
Old 04-03-2005, 06:01 PM   #9 (permalink)
vysakh's Avatar
in Alcohol 120% you can have 6 such virtual drives
in alcohol 120% go to file--options---virtual drive--number of virtual drives
to mount an image, open the image. It will appear in the main screen. Right click on it and select mount on device
Incompatible message format
vysakh is offline
Old 04-03-2005, 08:33 PM   #10 (permalink)
Bewitched!
xenkatesh's Avatar
how to burn an .iso image using nero...
Keep your friends close and enemy CLOSER!!!
Ragnarok Online: One World, One Million Possibilities..
xenkatesh is offline
Old 05-03-2005, 12:01 AM   #11 (permalink)
enoonmai's Avatar
Open Nero burning ROM, select Recorder>Burn Image and select the ISO to burn and check the options and click Write. If you have associated .iso files to Nero, you can even double click the .iso file to directly open Nero and the Burn Image window.
Playing FEAR XP/LSW2
enoonmai is offline
Old 05-03-2005, 02:00 AM   #12 (permalink)
parthbarot's Avatar
ya Alcohol 120% is the best thing to make images..
it also reads bad-scratched CDs & make images.
it supports...
ISO,IMG,CUE,BIN,VCD,CCD.
it makes...
CCD,ISO,CUE & its own MDF.
grt soft..small & sweet...
nero is bogus for imaging the CDs...though u can use its-----"copy tracks" button....& save image...
regards
www.techlads.com
Paarth.
parthbarot is offline
Old 05-03-2005, 09:39 PM   #13 (permalink)
Dipen01's Avatar
hey there..
i am using H+H software's Virtual CD 6.0 its simply awesome.... i guess good then even Nero image and Alcohol.. its more user frendly then alcohol.... u can find it at www.virtualcd-online.com
also one thin its no free... u can find its demo at its site.. worth a try...
i guess it was on feb digit also... am not sure...
Cheers..
Dipen
I love walking in Rain ,because no-one knows i am Crying
Dipen01 is offline
Old 07-03-2005, 09:25 PM   #14 (permalink)
hack expert's Avatar
well nero n alcohol have always been the best but bbesides there are many other softwares like clone cd which are also good
If electricty comes from electrons, does morality come from morons?
Flying is simple. You just throw yourself at the ground and miss
hack expert is offline
Old 09-03-2005, 12:47 AM   #15 (permalink)
hafees's Avatar
virtual CD compresses the CD. a 700 MB CD may be compressed to 400 MB image file. the problem is that u need Virtual CD software to open it unlike ISO. so if u want to make an image for burning then iso format is best. If u want to keep it for ur daily use then Virtual CD is good.
hafees is offline
Old 09-03-2005, 12:58 AM   #16 (permalink)
parthbarot's Avatar
@hafees..
r u sure that Virtual CD compresses this mush the CD 700 to 400??
if yes then thx for the information yaar...
& do keep any more sugestions of other good softies...
regards...
www.techlads.com
Paarth.
Old 10-03-2005, 09:52 AM   #17 (permalink)
Ignorance is BLISS !!
Use alcohol 120% for all such tasks
rajkumar_personal is offline
Old 11-03-2005, 11:08 PM   #18 (permalink)
Fresh Stock Since 2005
http://isorecorder.alexfeinman.com/isorecorder.htm
Easy to use
khattam_ is offline
Old 11-03-2005, 11:31 PM   #19 (permalink)
I feel that u should try out CLONE CD . It's a nice software to work with.
Althogh I feel that Alcohol 120% does not support a few formats.
Nero is also good.
suj_engico is offline
Old 11-03-2005, 11:37 PM   #20 (permalink)
Gaurav's Avatar
Virtual Clone Drive is just for that. alternatively you can use clonecd to make cd images which can be mounted using the virtual clone drive. it's the best because it can handle almost any protected cd.
Gaurav is offline
Old 12-03-2005, 04:00 PM   #21 (permalink)
enoonmai's Avatar
Just a slight warning, if you're a hardcore gamer, be warned that most new game installations will try to autodetect to see if Alcohol or BlindWrite is installed and require you to disable or uninstall them to load and play the game. Having said that, my personal vote goes to DAEMON-Tools. Did anyone mention that its free and can handle almost all copy protection schemes?
enoonmai is offline
