Old 20-02-2007, 12:19 PM   #1 (permalink)
Thumbs down php encoded
can u explain me how to install the loader.
this is the explanation that how to install the loader, but i can't understan dthis please someone explain me.
Run-time Loading Installation
The run-time loading method is the easiest way to run encoded files, and lets encoded files locate and install the correct Loader when needed.
Provided that run-time loading is supported on the target system, encoded scripts and Loaders can be bundled together without the user having to install any Loader or update their system configuration, and without having to know about the PHP version or operating system used.
For run-time loading to work, a directory called 'ioncube' containing the Loaders should be placed in or above the top directory of encoded files. For example, if you have encoded files in or below '/var/www/htdocs/', you might place the 'ioncube' directory in '/var/www/htdocs' or '/var/www'. If you have an application or library to distribute, you could place the ioncube directory within the top directory
http://www.ioncube.com/loader_instal....php:confused:
boosters is offline
Old 20-02-2007, 12:59 PM   #2 (permalink)
Host4Cheap.org
Sukhdeep Singh's Avatar
Default Re: php encoded
Just put loaders in the Root Directory of your hosting
http://www.host4cheap.org/
Sukhdeep Singh is offline
- by Piyush
