Old 19-02-2007, 11:59 PM   #1 (permalink)
fff..fire fire...
Binay 007's Avatar
Lightbulb Spyware !!!!!!!!!
guyes wat the hell is going . on Ebay whenever i try to login ,it ask me to save ------ eBayISAPI.dll----frm the site ,i know this is a .dll file but i dont know wat. type of it is wat it do ,i have some doubt on this i fill insecure on surfing ebay.Is this a spyware or somthing.
P4 2.93(GHZ) ,256 RAM,LG combo drive ,915GL-V mobo
DLink/intex int. modem
Binay 007 is offline
Old 20-02-2007, 01:33 AM   #2 (permalink)
nishant_nms's Avatar
Default Re: Spyware !!!!!!!!!
try scaning ur PC with Adaware and Spybot search & Destroy
nishant_nms is offline
Old 20-02-2007, 01:40 AM   #3 (permalink)
Arsenal_Gunners's Avatar
Are you going to www.ebay.com
it may be a phishing site you are trying to open.
Arsenal_Gunners is online now
Old 20-02-2007, 01:52 AM   #4 (permalink)
shashank4u's Avatar
its an internet server api(application programming interface)..
and i dont think it is a spyware..
Be like a postage stamp-stick to one thing until you get there.
shashank4u is offline
Old 20-02-2007, 01:57 AM   #5 (permalink)
thunderbird.117
Posts: n/a
This is the correct site :- http://www.ebay.in/.
Old 20-02-2007, 02:01 AM   #6 (permalink)
^^No this is ebay india,ebay global is .com
Old 20-02-2007, 02:15 AM   #7 (permalink)
shashank4u's Avatar
www.ebay.com global
http://www.ebay.in/ indian
BOTH R same sites..
company is same..
and u shudnt get that msg..
turn yr internet settings to default..
Old 20-02-2007, 02:19 AM   #8 (permalink)
thunderbird.117
Posts: n/a
Ah yes. I thought he should use indian ebay . But i did not get anysort of dll msg?.
Old 20-02-2007, 02:20 AM   #9 (permalink)
ApoorvKhatreja's Avatar
Zameen-Aasmaan ka farak hai in dono sites mein. Though they belong to the same company, they are meant for totally different people, living on opposite sides of the globe.
http://apoorvkhatreja.blogspot.com
ApoorvKhatreja is offline
Old 20-02-2007, 12:53 PM   #10 (permalink)
piyush gupta's Avatar
why not u scan ur PC for Spywars and Malwares
piyush gupta is offline
Old 20-02-2007, 01:39 PM   #11 (permalink)
Kiran.dks's Avatar
dll error on ebay using FF2.1 & IE6
Kiran Kumar R
Kiran.dks is offline
Old 20-02-2007, 01:40 PM   #12 (permalink)
You also thought it was a phishing attemptWe think on a same frequency
- by Piyush
