| Forum |
#1 (permalink) |
Error during check!: InterFun (Datei E:\WINDOWS\system.ini kann nicht geöffnet werden. The process cannot access the file because it is being used by another process) () Error during check!: Cabrotor (Datei E:\WINDOWS\win.ini kann nicht geöffnet werden. The process cannot access the file because it is being used by another process) () DSO Exploit: Data source object exploit (Registry change, nothing done) HKEY_USERS\S-1-5-18\Software\Microsoft\Windows\CurrentVersion\Inter net Settings\Zones\0\1004!=W=3 DSO Exploit: Data source object exploit (Registry change, nothing done) HKEY_USERS\S-1-5-21-436374069-2025429265-725345543-500\Software\Microsoft\Windows\CurrentVersion\Inte rnet Settings\Zones\0\1004!=W=3 DSO Exploit: Data source object exploit (Registry change, nothing done) HKEY_USERS\S-1-5-20\Software\Microsoft\Windows\CurrentVersion\Inter net Settings\Zones\0\1004!=W=3 DSO Exploit: Data source object exploit (Registry change, nothing done) HKEY_USERS\S-1-5-19\Software\Microsoft\Windows\CurrentVersion\Inter net Settings\Zones\0\1004!=W=3 DSO Exploit: Data source object exploit (Registry change, nothing done) HKEY_USERS\.DEFAULT\Software\Microsoft\Windows\Cur rentVersion\Internet Settings\Zones\0\1004!=W=3 --- Spybot - Search && Destroy version: 1.3 --- 2004-11-29 Includes\Cookies.sbi 2005-01-04 Includes\Dialer.sbi 2005-01-04 Includes\Hijackers.sbi 2004-12-29 Includes\Keyloggers.sbi 2004-05-12 Includes\LSP.sbi 2005-01-04 Includes\Malware.sbi 2004-08-11 Includes\plugin-ignore.ini 2004-11-29 Includes\Revision.sbi 2004-11-29 Includes\Security.sbi 2005-01-05 Includes\Spybots.sbi 2004-11-29 Includes\Tracks.uti 2005-01-04 Includes\Trojans.sbi |
#2 (permalink) |
hi,
Use "Ad-Aware SE Professional 1.05" with the latest Definitions. For Latest Definitions visit "h**p://www.lavasoft.com" and also "Webroots Spy Sweeper v3.5.0 Build 189" with the Latest Definitions. Try Both of them. These two are one of the best softwares in the world. Use these two softwares your problem may get solved. |
#5 (permalink) | |
this is the best combo
No Mercy, No Limits. Oobertech.net - Keeping Knowledge Free |
#6 (permalink) | ||
To remove the DSO Esploits you have to download and install a patch for SpyBot (you do have SpyBot, right?). You can get it here.
this link. Get the removal software here.
Hard work never killed anybody..........But why take the RISK |
| Bookmarks |
| Display Modes | |
