| Forum |
#1 (permalink) |
Core i7 (nehalem) Owner
Anyways anyone who would like to get hints on this game do make a plunge in this discussion and i will try to help u with as many topics as i can. So long then GAMING COMMUNITY !!! BYE ANDy...... |
#2 (permalink) | |
well am a gamer but i like playing first person shooter,racing games..my fav is NFS,SWAT,Theif 2 etc etc..but at this moment i cant NFS ug...I have to upgrade my PC,but there r some constraints 4me now..Could u tell me whats the least specification to play this game. |
#3 (permalink) |
Well The Minimum Requirements State:
Windows 98, 98 Second Edition, ME, 2000 Professional, XP Professional, or XP Home operating system Intel Pentium III (or compatible) CPU running at 933Mhz or higher32MB DirectX 9 compatible video card (Geforce2 or higher) using a supported chipset (see below) 256 MB RAM DirectX compatible sound card 2 GB of HD space 8X CD-ROM But Still Dun Go By The Specs It will Need PIV 1.7Ghz Or Amd Athlon Xp 2000+ Processor,128MB Graphics Card (Just To Be Safe For The Rest games And for Some time In The Future too.....Consider Minimum Ati Radeon 9600Pro Or Xt Or The Geforce Fx5700).....Plus Atleast 256MB Ram To Run It Smoothly 8) |
#4 (permalink) |
The minimum requirements for Need for Speed Underground 2 are -
Windows 98/Me/2000/XP 933MHz CPU 256MB RAM 32MB DirectX 9-compatible video card (Geforce2 or higher) 8x CD ROM Drive It must be considered that the game will run only at the minimum settings at this configuration & hence most of the visual enhancements that you make to ur car will not be seen unless you play at higher settings. But on the contrary, at higher settings the game will not run properly. So plan your upgrade carefully. The recommended configuration for this game would be atleast - 2Ghz CPU 256RAM 128 MB DirectX 9-compatible video card This configuration will also allow you to play most new games at more than acceptable frame rates at higher settings |
#5 (permalink) |
search b4 posting...there is already a long thread on NFSU2 running right here in software discussion:
http://www.thinkdigit.com/forum/view...s+undeground+2 |
| Bookmarks |
| Display Modes | |
