Old 19-02-2007, 05:02 PM   #1 (permalink)
~[::BOoYaKa::]~
Default Javascript Help
Can nayone tell me what does this javascript code do...
<script language="JavaScript">
function passwd()
var x="a" + "k";
var base = "Fqc";
var code="";
var end = "";
for (var z=0;z<base.length;z++)
code=code+String.fromCharCode(base.charCodeAt(z)+z);
end = code + x;
if(document.check.passwort.value==code)
document.write("Access Granted, please type it in and press submit.");
else
document.write("Access Denied.");
</script>
Thanx.
[::Eddie n Benoit Live Forever::]
REY619 is offline
Old 20-02-2007, 07:24 AM   #2 (permalink)
eWebGuru
ahref's Avatar
Default Re: Javascript Help
this code check the password entered and validate whether it is correct or not. If correct write on browser Access Granted, please type it in and press submit
if wrong write on browser Access Denied.
You can find what the password is through above code easily.
Windows and linux hosting at http://www.ewebguru.com
Get $50 per blog post PM me for details.
ahref is offline
Old 20-02-2007, 04:45 PM   #3 (permalink)
~[::BOoYaKa::]~
lol thats the reason why i posted it. I am unable to find the password...
REY619 is offline
Old 20-02-2007, 09:23 PM   #4 (permalink)
eWebGuru
ahref's Avatar
The password is Fre
ahref is offline
Old 21-02-2007, 08:09 PM   #5 (permalink)
~[::BOoYaKa::]~
Thanx
REY619 is offline
Old 21-02-2007, 09:31 PM   #6 (permalink)
ApoorvKhatreja's Avatar
The password is Fre. It will grant you access on entering it.
http://apoorvkhatreja.blogspot.com
ApoorvKhatreja is offline
- by Piyush
