Old 23-01-2005, 11:54 PM   #1 (permalink)
Default Quake 3 FPS drops drastically!!!
I have an Acer travelmate 240 notebook
specs are: P4 2 GHz , 256 MB RAM,
i often play Quake 3 on that . Earlier it used to show an FPS of around 90 but since 1 month, after around 15 mins. of play the FPS drops to 30-40 ....... I used 'mobmeter' to know the temp ....it rises to around 70 C ....... The laptop is only 10 months old ....... is it due to the Rise in Temp. of processor..... suggest some solution !!!
Shine on ! You crazy diamond !!!
pag_floyd is offline
Old 24-01-2005, 12:05 AM   #2 (permalink)
Do you regularly do these
1. Disk Clean Up
2. Scan Disk
3. Disk defragment
4. Antivirus Scan
5. Spyware Scan
6. Registry Check Up Scan
Do these and you will find a good performance jump
Do these at least once a month for ur pc to be in good shape.
Have a Nice Day :)
Mohammed Muchhala, © 2006, All Rights Reserved
http://www.muchhalasworld.com
babumuchhala is offline
Old 24-01-2005, 06:20 PM   #3 (permalink)
...nothing related to that...... Read carefully...... I said it's alright for first 15 mins. , after that the problem starts..........anybody using the same laptop, is the temp. ok??
- by Piyush
