LinkBack (1) Thread Tools Search this Thread Display Modes
Old 18-02-2007, 09:58 PM   1 links from elsewhere to this Post. Click to view. #1 (permalink)
Kiran.dks's Avatar
Arrow DOWNLOAD: Patch for Cyberlink PowerDVD 7.0
CyberLink PowerDVD 7.0 Patch
Patch for build number smaller then 2414
Patch Details:
Version: 7.0
File Size: 40.3 MB
Release Date: 02/09/2007
Note:
  • This patch does NOT apply to bundled versions of PowerDVD.
  • This patch is for PowerDVD 7 users. Users of PowerDVD Ultra should not apply this patch.
  • Please check the PowerDVD build number. If the build number of your current program is smaller then 2414, then you can apply this patch.
  • This patch applies to users who have installed previous PowerDVD 7 builds on Windows 2000, XP and Vista.
  • Please prepare your current PowerDVD 7 CD-Key which is required to install this patch. If you have lost your CD-Key but have registered the software, you can log in to our Members Zone to check for your CD-Key.
Problems List:
  • This patch includes improved Windows Vista compatibility for PowerDVD 7.
  • There is no audio while playing VCD title.
  • PowerDVD can't play VCDs
  • PowerDVD can't be used after activating the Deluxe version and reinstalling the trial version.
  • PowerDVD hangs when MPEG2 audio is switched to 48KHz PCM audio.
  • When playing a DVD-VR disc you can't go to the correct playlist if audio format is MPEG1.0/2.0.
  • On-line Register is not being installed.
  • PowerDVD hangs when a disc containing .wmv files is inserted.
  • Help file version is wrong.
  • Remote control can't launch PowerDVD if Windows is not rebooted.
  • Playing certain copyright protected discs causes PowerDVD to hang.
Download: Power DVD 7.0 Patch
Kiran Kumar R
Kiran.dks is offline
Old 18-02-2007, 11:32 PM   #2 (permalink)
nishant_nms's Avatar
Default Re: DOWNLOAD: Patch for Cyberlink PowerDVD 7.0
thanx
nishant_nms is offline
LinkBack to this Thread: http://www.thinkdigit.com/forum/qna-read-only/49912-download-patch-cyberlink-powerdvd-7-0-a.html
Google egyszer? keresés This thread Refback 04-12-2010 04:47 PM
- by Piyush
