Old 18-02-2007, 07:35 PM   #1 (permalink)
BlackBerry Guru ! :)
BBThumbHealer's Avatar
Default Beep.........
when my pc boots up ... the beep sound which normally comes is not coming ......wat cud b the prb ???
Thnx
BlackBerry7100g
Username Changed - BlackBerry7100g To BBThumbHealer ! :D
BBThumbHealer is offline
Old 18-02-2007, 07:38 PM   #2 (permalink)
Super Hero - Super Powers
n2casey's Avatar
Default Re: Beep.........
If u r not facing any other prob then it can b possible that speaker which gives beep sound has failed or it has a loose connection. It a buzzer is there on ur mobo for beep, then check if it is working or not.
Minds are like Parachutes :arrow: They work best when open
n2casey is offline
Old 18-02-2007, 07:41 PM   #3 (permalink)
a_g = JPKN
s18000rpm's Avatar
my PC has never beeped when booting (both ASUS 915g based HP Pavilion & Intel DG965WH m/b).
normally if the system beeps then it means trouble, am i right???
ASUS K53SV SX520D + BF3
s18000rpm is offline
Old 18-02-2007, 08:10 PM   #4 (permalink)
nishant_nms's Avatar
^^no, single beep is right
nishant_nms is offline
- by Piyush
