Old 18-02-2007, 05:57 PM   #1 (permalink)
Default Disappearing free space on 'C' crive
Am using Win XP Pro SP 2 with 2 x 256 mb ram.
Since the last more thn a week am facing a strange problem. This came to light when I got messge "No free space to save file". On checking propery of 'c' Drive I found no free space left.
I restarted the machine and on rechecking property of 'c'drive I found that all the free pace was restored.
Thereafter every moring on start up the used space is 5.81 gb; Free space is 14.1 gb and capacity 29 gb.
Even if I let the computer idle for few hours I find that the free space is decreased and used space increased. By the end of the day there is no free spaceleft.
Have to restart to regain free space.
Can any one of you help me to understand what is happenning?
Have trid scanning with online scnners and nothing is reported.
I eagerly wait to receive some help.
REGARD
nariman
Nariman is offline
Old 18-02-2007, 06:22 PM   #2 (permalink)
Arsenal_Gunners's Avatar
Default Re: Disappearing free space on 'C' crive
This must be windows page file...
Arsenal_Gunners is online now
Old 18-02-2007, 06:51 PM   #3 (permalink)
Google Bot
Pathik's Avatar
it can be a virus too... scan wit avast....
btw @ vimal page file size doesnt increase dynamically...
Pathik is offline
Old 18-02-2007, 06:56 PM   #4 (permalink)
^^Even if we check the "automatically set the pagefile"(or similar) option?
Old 18-02-2007, 07:11 PM   #5 (permalink)
a_g = JPKN
s18000rpm's Avatar
if "Automatically set the pagefile" option is enabled then it will go max to 1.5 times the RAM size =>(2*256)*1.5 = 768MB
btw scan with Kaspersky AV (trial edition will do for one time scan), coz Avast is no good , just now i installed KIS & currently running Full System scan & it has found 5 trojan & 2 adwares. (two hours ago i had Avast & had installed XP 3 hours ago )
ASUS K53SV SX520D + BF3
s18000rpm is offline
Old 20-02-2007, 11:05 AM   #6 (permalink)
Hi
Tried everything suggested but no go.
Nariman
Nariman is offline
Old 20-02-2007, 03:56 PM   #7 (permalink)
check your drive for bad sectors....
ismart is offline
Old 23-02-2007, 11:24 AM   #8 (permalink)
cooldip10's Avatar
Do a quick Virus Scan.. My father faced the same problem a few days ago..
__________
Originally Posted by s18000rpm
Avast is no good ,
May i know who said that.??
Its much better than the resource hungry Norton!
Everything is Possible
cooldip10 is offline
Old 23-02-2007, 11:26 AM   #9 (permalink)
shashank4u's Avatar
first defragment the disk then see..
check for the viruses..
restore the computer when it was working fine..
check these 3 options and then tell us..
Be like a postage stamp-stick to one thing until you get there.
shashank4u is offline
Old 23-02-2007, 11:36 AM   #10 (permalink)
a_g = JPKN
s18000rpm's Avatar
dude, when i posted it, then it means i said it lool
& i gave the reason in post # 5.
what good is a AV when it cant detect virus/trojan.
i had d/l a zip file & Avast said its all cool, so i opened the zip file & used the contents, then the Internet Explorer got fked
KIS on the other hand, caught the culprits
so IMHO Active Virus Shield [free] (AVS) is a lot better choice than Avast coz it uses Kaspersky Engine
Old 23-02-2007, 12:08 PM   #11 (permalink)
Kiran.dks's Avatar
REGARD
nariman
It is clearly a Trojan or spyware issue. Post the HijackThis log report for analysis.
Meanwhile, Install "Spybot" and avast! Antivirus, update its definitions and perform a full scan in "safe mode".
Kiran Kumar R
Kiran.dks is offline
- by Piyush
