Old 18-02-2007, 08:44 AM   #1 (permalink)
Default batch files
i have heard that u can use batch files to automate tasks..can someone write me a batch file which will shutdown my system (win2000) at the following intervals
9:45 am
10:30 am
11:40 am
1:45 pm
2:30 pm
will it be enough if i click on the batch file once? can i delete it later, after clicking on it?
Suhas M is offline
Old 18-02-2007, 08:54 AM   #2 (permalink)
Still Shining!
Lucky_star's Avatar
Default Re: batch files
Why don't you use auto shutdown softwares like Autopoweron and Shutdown
Nokia N86 8MP
Lucky_star is offline
Old 18-02-2007, 08:59 AM   #3 (permalink)
i don't want to use these softwares, thats why i'm going for batch files
Suhas M is offline
Old 18-02-2007, 09:04 AM   #4 (permalink)
Still Shining!
Lucky_star's Avatar
For shutting down or restarting, this might help.
shutdown.exe -s -t xx
Here s stands for shutdown and t stands for the number of seconds in xx before shutdown.
I don't know how to set a particular time for that using DOS commands.
You can make a batch file out of it and later use Windows Scheduler to run it at your required times.
Nokia N86 8MP
Old 18-02-2007, 02:13 PM   #5 (permalink)
ApoorvKhatreja's Avatar
@ echo off
shutdown -s -t xx
Replace the xx with the time limit after which computer is to be shutdown. If you want immediate shutdown, with no delay, set the xx value to 0.
http://apoorvkhatreja.blogspot.com
ApoorvKhatreja is offline
Old 18-02-2007, 03:12 PM   #6 (permalink)
is possible to shutdown the system once every hour?
Suhas M is offline
Old 18-02-2007, 04:15 PM   #7 (permalink)
Yes. Save this as anything.bat. Then using FDM (Free Download Manager), schedule it to run every 1 hours.
- by Piyush
