I downloaded a file which was split in the format:
Image.org.iso.001
Image.org.iso.002
[To the end]
Image.org.iso.041
There were total 41 parts and hjsplit was used to split the file and hence hjsplit was used to join them.
http://www.freebyte.com/hjsplit/#win32
http://www.treepad.net/download/hjsplit.zip
After making the image.org.iso file, I renamed the file to image.iso and tried to load it to my Virtual Drive created using PowerISO 3.5. There was an error message which is attached with this post as an image file [poweriso_image_error.gif]
Tried loading it onto NeroImage drive. Loading was successfull but then nothing was shown. When trying to open/explore the drive an error message was given, attached [Nero_mount_image_open_errormsg.gif] I am using Nero 7 Ultra Edition.
Loading onto ISO Buster also gave an error message, attached [IsoBuster_msg.gif]. Using IsoBuster Pro ver 2.0. Trying to recover the missing files resulted in failure.
Using UltraISO I could not open the files , showed error, attached [UltraISO_error.gif] using UltraIso 8.6.1.1985
I have attached the image of interface for hjsplit 2.3 (which is the latest release)..[hjsplit_2.3.jpg]
1. What is the problem with this ISO file?
2. What can I do to recover the data?
3. Did I do something wrong in joining the split files?
I am using Windows XP Pro SP2 - Core2Duo E6600/IntelDP965LT/2GB 667DDR2/Maxtor160GB HDD/nVidia7600GT256MB/Panasonic DVD-RAM
Any help, asap would be appreciated!
