Old 23-01-2005, 01:53 PM   #1 (permalink)
Default Blue error Screen in XP
hey guyz i just upgraded my pc to P4,256 DDRAM,intel 82845 Motherboard. I use heavy applications like vb.net and oracle 9i. i m using windows XP (home n pro both).My problem is that after doing everything fine sometimes a blue error screen comes up showing a message :
IRQL_NOT_LESS_OR_EQUAL
CAN BE DUE TO NEWLY INSTALLED H/W OR S/W ......OTHERLINES
PLZ TELL ME WATS WRONG....... IF INFO IS NOT SUFFICIENT PLZ TELL ME.......
Ashootosh is offline
Old 23-01-2005, 02:38 PM   #2 (permalink)
dIgItaL_BrAt's Avatar
that error is usually due to a faulty driver.
dIgItaL_BrAt is offline
Old 23-01-2005, 03:14 PM   #3 (permalink)
alib_i's Avatar
see links if they help
http://www.thinkdigit.com/forum/view...&highlight=irq
alibi
-Metallica
alib_i is offline
Old 23-01-2005, 03:57 PM   #4 (permalink)
Some device driver is either faulty or incorrectly configured. The solution is in the support section of www.microsoft.com, I am assuming you are eligible for tech support from ms.
^ I wrote this!
akshayc is offline
Old 23-01-2005, 04:06 PM   #5 (permalink)
Is the RAM in ur system is in 2 chips or single.
Dude I had the same problem when I upgraded my RAM, then I bought a single chip of 256 MB RAM and since then no BLUE SCREEN of Death.
enjoy is offline
Old 24-01-2005, 03:21 PM   #6 (permalink)
i m using single 256 RAM. But i found an interesting thing,when i changed my 256 RAM with 128, the error screen stopped coming............... so i guess the problem was with RAM. But i cant use 128 RAM..... so i m going to change my 256 RAM. but i still have some doubts in my mind.
Old 24-01-2005, 09:49 PM   #7 (permalink)
alib_i's Avatar
before doing anything else ...
just check if your RAM is really corrupted or not !!
use MEMTEST
or use MEMTEST86
Both are good utilities !
alibi
-Metallica
alib_i is offline
- by tv6952
