Old 23-01-2005, 12:09 PM   #1 (permalink)
Default what is this message ????????
My computer is showing this message many times,i dont know what actually it is,so can anyone help me to get rid of it!!!!
the instruction at "0*0807747e" referenced memory at "0*00000001".the memory could not be "read".
click ok to terminate the program
click on cancel to debug the program
ok cancel
neerajvohra is offline
Old 23-01-2005, 01:03 PM   #2 (permalink)
Most probably ur PC must have got some kind of antivirus or spyware which has resulted in some file getting curropted.
Do a through scan of your system, with antivirus, spyware removal tools and registry mechanics.
See if the problem gets solved(should get solved)
Lastly you might have to reinstall windows
Have a Nice Day :)
Mohammed Muchhala, © 2006, All Rights Reserved
http://www.muchhalasworld.com
babumuchhala is offline
Old 23-01-2005, 08:09 PM   #3 (permalink)
no viruses in my computer,and no ad aware and spyware at all,so another than that why cant it be solved without installing windows??????cant be solved without it!!!!!!!!!!!!!!!
Old 23-01-2005, 08:47 PM   #4 (permalink)
Web Entrepreneur
ShekharPalash's Avatar
it looks like a temp corrupted RAM.. i think its related to any blocked info/data in ya RAM...
Live Chat with Doctors 24x7 on my site http://healthcaremagic.com
ShekharPalash is offline
Old 23-01-2005, 10:41 PM   #5 (permalink)
how to correct it then????????????
Old 24-01-2005, 12:13 AM   #6 (permalink)
You can check if your RAM module is faulty or not using this utility software. But if you decide to use it, read the instructions carefully, its a looooong process, might take more than 24 hours to complete the process, depending on your CPU speed and amount of RAM installed.
Hard work never killed anybody..........But why take the RISK
indrajit is offline
Old 24-01-2005, 02:27 PM   #7 (permalink)
Other than that my computer is showing ram 1022mb instead of 1024 mb.what can the reason behind it,i dont tries ur option indrajit,cant go for long process at all,so suggest me the best way out!!!!!
Old 24-01-2005, 03:24 PM   #8 (permalink)
You've got 1024 MB of RAM on your system? WOW! That's a lot of memory!
Anyway, if you have an Intel mobo, then usually 2MB of primary memory goes into system sharing.
indrajit is offline
Old 24-01-2005, 11:43 PM   #9 (permalink)
Yes i have intel mother board!!
so is this so that it is showing lesser amount,ok
thx
- by Piyush
