Old 14-02-2007, 10:03 PM   #1 (permalink)
Curious Guest's Avatar
Wink Display problem???
Recently my XP Home desktop has become 'jarky' as all icons shakes a lot following rt click & refresh. There was no shakes few days ago.
May be a bit silly to ask but can anyone help me to restore original settings?
Thanks.
_____________________________________
THE HELL IS FULL SO I AM BACK WITH DIGIT.
Curious Guest is offline
Old 14-02-2007, 10:08 PM   #2 (permalink)
Kiran.dks's Avatar
Default Re: Display problem???
There are "n" number of reasons for system slowing down producing that effect. Check out the CPU utilization at that time. Possible that any program is running in the background. If you are sure about it, then use "System Restore" to the best working time.
Kiran Kumar R
Kiran.dks is offline
Old 14-02-2007, 10:19 PM   #3 (permalink)
Thanks Kiran, but system is pretty fast as before and system restore is disabled.
Old 14-02-2007, 10:32 PM   #4 (permalink)
Kiran.dks's Avatar
Ok. I suggest you to rebuild Icon Cache using Free Tweak UI from Microsoft.
Download and install it.
Start>Control Panel> Tweak UI..
Use the rebuild Icon Cache in it.
EDIT: TweakUI link corrected. Earlier link was not compatible with WindowsXP.
Kiran Kumar R
Old 14-02-2007, 10:45 PM   #5 (permalink)
Microsoft MVP
Vishal Gupta's Avatar
When the wallpaper is set as "Tiles" or "Centre", then u may face such problem.
Try to set the wallpaper as Stretch.
:arrow: http://www.AskVG.com/
Vishal Gupta is offline
Old 14-02-2007, 10:53 PM   #6 (permalink)
How to disable web content on desktop???
__________
Got it. Rt click property.......desktop.......customise desktop.........web.......unchek lock desktop items.
Prob solved. Thanks to you all'
Last edited by Curious Guest; 14-02-2007 at 10:53 PM. Reason: Automerged Doublepost
