Old 14-02-2007, 12:28 PM   #1 (permalink)
Default DVD region coding
if i buy a dvd movie from amazon.com (with region coding 1), will it work in india, on pc's dvd writers?
digit_rajesh is offline
Old 14-02-2007, 03:19 PM   #2 (permalink)
aryayush's Avatar
Default Re: DVD region coding
Why do you want it to work with a DVD writer?
If you mean to say, a DVD-ROM, the answer is yes, it will.
aryayush is offline
Old 14-02-2007, 03:35 PM   #3 (permalink)
Debian Rocks!
freebird's Avatar
Smile Re: DVD region coding
In Linux,all dvds play irrespective of their region coding,thanks to libdvdcss2
"The day windows users wake up to reality, it will be doomsday for Microsoft."UNIX like OS are more secure.get urself out 4m M$ http://whylinuxisbetter.net http://tinyurl.com/2amjjc http://fsf.org
freebird is offline
Old 14-02-2007, 06:30 PM   #4 (permalink)
aryayush's Avatar
I think you can do nothing about it if the drive itself is region-coded. I could be wrong though.
aryayush is offline
Old 14-02-2007, 07:12 PM   #5 (permalink)
The Frozen Nova
casanova's Avatar
DVD-ROM/RW are restricted to changing the region codes to 5 times. If you change the region code 5 times, you will not be able to change it again even if u reinstall windows or anything.
@freebird
We can do the same in Windows. There are many softwares allowing this including the popular DVD+Region CSS Free
www.nerdweed.blogspot.com
casanova is offline
