Old 14-02-2007, 10:15 AM   #1 (permalink)
Default how to use this?
from where to copy n paste?? i m unable to paste in IE7..why ??
<script>
Auto Refresh Page with Time script
By JavaScript Kit (javascriptkit.com)
Over 200+ free scripts here!
//enter refresh time in "minutes:seconds" Minutes should range from 0 to inifinity. Seconds should range from 0 to 59
var limit="0:30"
if (document.images){
var parselimit=limit.split(":")
parselimit=parselimit[0]*60+parselimit[1]*1
function beginrefresh(){
if (!document.images)
return
if (parselimit==1)
window.location.reload()
else{
parselimit-=1
curmin=Math.floor(parselimit/60)
cursec=parselimit%60
if (curmin!=0)
curtime=curmin+" minutes and "+cursec+" seconds left until page refresh!"
else
curtime=cursec+" seconds left until page refresh!"
window.status=curtime
setTimeout("beginrefresh()",1000)
window.onload=beginrefresh
</script>
NagpurDaMunda is offline
Old 14-02-2007, 04:42 PM   #2 (permalink)
Lightbulb Re: how to use this?
This is a javascript code
Open notepad
and paste the following code:-
<script>
var limit="0:30"
return
if (parselimit==1)
else{
parselimit-=1
if (curmin!=0)
else
</script>
and save it as .js
and then call it from ur browser
or if .js doesnt work then save it as .htm or .html
You can also embeed it with ur website to autorefresh ur site after some time.
Visit now ;)
www.indiandevs.com - for great free designs :)
www.indiandevs.com/technoworld/ for latest technology news and tricks
Siddharth Maheshwari is offline
Old 14-02-2007, 07:16 PM   #3 (permalink)
Question Re: how to use this?
Open notepad
<script>
var limit="0:30"
return
if (parselimit==1)
else{
parselimit-=1
if (curmin!=0)
else
</script>
and save it as .js
i want to use it for every web page which i surf ...how to do it?
Old 14-02-2007, 08:07 PM   #4 (permalink)
Then u have to use opera for this cause as it suports the use of java script in sites.
open any site in opera and goto Tools>Quick Preferences>Edit Site Preferences
from here select scripting tab and now check “Enable Javascript” option and at the bottom of this you will find “User Javascript files”. Click on choose and select the folder in which you have saved the .js file.
For other browsers ( source for this )
In Firefox, you need to download the extension Greasemonkey
In IE try it with Trixie. But, cant garauntee that it will work.
Some more for iE : 1 2 .
Remeber save this script as .js only
Note:- IF u r writing a mail and suddenly the page refreshes the n uwill loose what hav u written
Visit now ;)
Old 15-02-2007, 09:57 AM   #5 (permalink)
Coming back to life ..
it_waaznt_me's Avatar
Default Re: how to use this?
This is built in in Maxthon
Maxthon > Tools > Auto Refresh Tab > Use Auto Refresh (interval)
And I wait without you ...
With or without you ..
Batty = Too Busy Now !!!
it_waaznt_me is offline
Old 15-02-2007, 10:38 AM   #6 (permalink)
thanks ll try Maxthon
__________
i tried this but it isnt working
__________
yes maxthon solved my purpose
Last edited by NagpurDaMunda; 15-02-2007 at 10:38 AM. Reason: Automerged Doublepost
