Old 09-08-2004, 08:08 PM   #1 (permalink)
Default Installing two Optical Drives
Can any body help me in installing two optical CD drives. How can I connect two at a time?[/b]
Get In Touch With ME!!!!
SID
sid_b6505 is offline
Old 09-08-2004, 08:42 PM   #2 (permalink)
gxsaurav
Posts: n/a
U can install both on the same IDE Channel, one as master & other as slave, just make sure the jumpas on the Drives are connected rite, better if U call the service guy & let him do it, just tell him that instll both on the same channel it is recomended to let the HDD on it's own independent channel
Old 24-03-2005, 02:58 AM   #3 (permalink)
dOm1naTOr's Avatar
First give a full data cable for the two data cable for the 2 optical drives.
Now connect the optical drive on the topmost pin on cable.This is the P Master nd the 2nd is Primary Slave.The jumper positions are marked in the back of the optical drive nd connect it according to Ur choice.The one which U like to make the master is plugged in the upper port of the cable nd the jumper is set to the cotrresponding position.Similarly the slave also.
dOm1naTOr is offline
Old 24-03-2005, 08:45 AM   #4 (permalink)
Another Brick in the Wall
drgrudge's Avatar
It's simple...
Primary Master - Hard Disk [mandatory]
Primary Slave - Hard Disk OR Optical Drive
Secondary Master - Optical drive (optical drvie one)
Secondary Slave - Optical Drive (optical drive two)
When i installed two optical drives, i dint bother to change the jumpers, and it worked fine.
drgrudge is offline
Old 24-03-2005, 09:11 AM   #5 (permalink)
in addition , make sure ur using 80 conductor cable for HDD and 40 conductor cable for optical drives is ur using doc's drive settings above . For 80 conductor cable , make sure blue end is fixed to the m/b , grey in middle is blank or optical drive and black end is to the HDD
If you make yourself more than just a man, if you devote yourself to an ideal... You become something else entirely
klinux is offline
