Old 13-02-2007, 12:28 PM   #1 (permalink)
Gracias Senor
dreams's Avatar
Smile Vcd - Dvd
Hi all..
This is a general question..
I have a Sony VCD Player 2000w PMPO.
Is it possible to convert this VCD player to a DVD player..cos before i had a Audio CD Player and the technician told to change it to VCD Player by simply changing the Lens..
So will the same can be done frm VCD - DVD..
I askd the sony people and they told its not poss cos the board also needs to b changd..
So need clarification frm the techies..
TIA
iPT 2G(S) - 8GB - JBn
iPhone 3GS 16GB - JBn
MAC OSx86 on P4 2.4Ghz
HTC Touch - Elfin - P3452 - WM 6.5
- Dont Dre@m... Juz Chase it -
dreams is offline
Old 13-02-2007, 12:47 PM   #2 (permalink)
Default Re: Vcd - Dvd
It is not possible...plz buy DVD.
ismart is offline
Old 13-02-2007, 03:00 PM   #3 (permalink)
parthbarot's Avatar
Smile Re: Vcd - Dvd
see. it not only requires lens ok? its having a small board like motherboard in PC. So think it like a PC. u cant read DVD with only a lens. u need to change more things and don't trust any local vendor... they will cheat u... bcs if u have original company player then may be it got worst after u get it back from those guys..
i suggest to buye u..
1.philips DVD player which supports Divx ,mp4... dont rememebr the model but goto showroom and ask them abt it. costs around 5 to 6K.
2. Samsung DVD player which supports HDTV and Divx,MP4 also...so i think u shld go for this one...
it will cost around 8 to 9K. but it support HDTV..so try for it...
and do more asking regarding this... may be someone have some other options... but these two are quite good..
www.techlads.com
Paarth.
parthbarot is offline
Old 15-02-2007, 09:48 AM   #4 (permalink)
Gracias Senor
dreams's Avatar
thnx guys..keep the postin flowin..
dreams is offline
- by Krow
