Old 13-02-2007, 12:27 PM   #1 (permalink)
saipradeepg's Avatar
Red face Real Tech Query!
My computer is locked{Physically}.The Cabinet can't be opened.There is a USB port.But the problem is the USB port has been disabled logically.I dont know the BIOS setup password too...to enabled it.But had some data which needs to be transfered.Of course i can connect an external writer throgh printer port but i dont want that way.Can anyone suggest other techniques through which i can enable the USB port.Thanks a Ton in advance...
Pradeep G.
saipradeepg is offline
Old 13-02-2007, 12:46 PM   #2 (permalink)
::cyborg::'s Avatar
Default Re: Real Tech Query!
try a linux live cd to access usb
plz elaborate ur problem
:)) - KEEP SMILING
::cyborg:: is offline
Old 13-02-2007, 12:59 PM   #3 (permalink)
Security Exp
47shailesh's Avatar
Cool Re: Real Tech Query!
1. Click Start, and then click Run.
2. In the Open box, type regedit, and then click OK.
3. Locate, and then click the following registry key:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Servic es\UsbStor
4. In the right pane, double-click Start.
5. In the Value data box, type 3, click Hexadecimal (if it is not already selected), and then click OK.
6. Quit Registry Editor.
__________
@cyborg he already mentioned he cannot open Cabinet nor can enter in to BIOS.... So ur trick will wont work untill first boot option is set to "Boot from CD" by default from the mc administrator..
We Love Once, And When We do We do it Well
47shailesh is offline
Old 13-02-2007, 01:10 PM   #4 (permalink)
::cyborg::'s Avatar
oops sorry for that
:)) - KEEP SMILING
Old 13-02-2007, 02:33 PM   #5 (permalink)
Red face Re: Real Tech Query!
Hi,
Sorry but i dont have that folder Usb... under services i checked that out!! Any other way ...? Thanks...
Old 13-02-2007, 02:43 PM   #6 (permalink)
Security Exp
47shailesh's Avatar
If you do not have USBstor in service in registry then surely...USB devices is not installed on ur system...
Do the following to remove restrictions(i.e. to enable) on USB usage...
If a USB storage device is not already installed on the computer, assign the user or the group Deny permissions to the following files:• %SystemRoot%\Inf\Usbstor.pnf
• %SystemRoot%\Inf\Usbstor.inf
To assign a user or group allow permissions to the Usbstor.pnf and Usbstor.inf files, follow these steps:
1. Start Windows Explorer, and then locate the %SystemRoot%\Inf folder.
2. Right-click the Usbstor.pnf file, and then click Properties.
3. Click the Security tab.
4. In the Group or user names list, click the user or group that you want to set allow permissions for.
5. In the Permissions for UserName or GroupName list, click to select the allow check box next to Full Control, and then click OK.
Note In addition, add the System account to the allow list.
6. Right-click the Usbstor.inf file, and then click Properties.
7. Click the Security tab.
8. In the Group or user names list, click the user or group that you want to set allow permissions for.
9. In the Permissions for UserName or GroupName list, click to select the allow check box next to Full Control, and then click OK.
__________
source:: http://support.microsoft.com/kb/823732
Then u need to install the device and use it
Old 13-02-2007, 03:10 PM   #7 (permalink)
Dear Shailesh,
Thanks a lot for your detailed help.Kindly answer some more queries of mine.The Os is WinXp.I opened the Usbstor.pnf file there is only general tab but there is no security tab...
Sincere Regards,
Sai Pradeep
Old 13-02-2007, 03:25 PM   #8 (permalink)
Security Exp
47shailesh's Avatar
Originally Posted by saipradeepg
Dear Shailesh,
Sincere Regards,
Sai Pradeep
saipradeepg can you tell me the file system of the partition on which ur XP resides
Old 13-02-2007, 03:47 PM   #9 (permalink)
Exclamation Re: Real Tech Query!
Hai its FAT32
Thanks,
Sai Pradeep
Old 13-02-2007, 03:59 PM   #10 (permalink)
Security Exp
47shailesh's Avatar
that the reason ur not able to see, security tab...
it an NTFS feature..
can you tell me the what can observe abt the USB device in device manager..
Old 13-02-2007, 04:33 PM   #11 (permalink)
Hi,
Even i tried that option before...There is no such thing in the device manager.There is no section for ports
Old 13-02-2007, 05:06 PM   #12 (permalink)
Security Exp
47shailesh's Avatar
have you tried installing USB drivers in ur system ??
- by Krow
