for forum information, i dont have any idea.... but for setting hub, find info below...
To host ur Hub,
1.Download ptokax server from
http://www.ptokax.org/downloads.html
extract d contents.
Leave the default settings except those mentioned below.
2.Type in ur ip address in "Hub Address(IP or Hostname)"
u can get ur ip by Start->Run->command->ipconfig
Check Autostart option,remove the default string (dreamland.gotdns.org) from the register address
Do other "fancy" things u want like Hubname,Description n all
3.Set d rules under Rules Tab like MinShare,Minslots..
4.Under option Tab,check "Enable tray icon" and "Minimize on startup"
4.Configure ur firewall(if any).
5.Press "Start hub" button under Network n u have done it.
6.Post ur ip in dis section
cmon ppl,lets make it 24x7 sharin hub
