Old 10-02-2007, 10:09 PM   #1 (permalink)
JhonCena's Avatar
Exclamation Pagerank N/A!!!
I have launched a Free Blog Directory. I am using phpld 2.1. The problem is with pagrank. I am not able to view pagrank of the sites in my directory. The pg is N/A
Why!!!!!
Help me plzzzz.
note the address is: http://www.blogzdirectory.com/
Thnaks.
----------> http://www.blogofwebmasters.com/ <---------
WEBMASTERING TUTORIALS, ARTICLES AND MUCH MORE
JhonCena is offline
Old 10-02-2007, 10:39 PM   #2 (permalink)
Google Bot
Pathik's Avatar
Default Re: Pagerank N/A!!!
i suppose u should ask that here...
http://www.phplinkdirectory.com/forum/
Pathik is offline
Old 10-02-2007, 11:45 PM   #3 (permalink)
I am Optimus Prime
navjotjsingh's Avatar
PageRank needs to be updated manually for all sites in your directory. PageRank display does not fetch pageranks automatically.
Here you can use this tool to update PR for all sites in the directory.
http://www.directoryspy.com/download...ool-for-phpld/
navjotjsingh is offline
Old 11-02-2007, 08:20 AM   #4 (permalink)
JhonCena's Avatar
Thanks to both of you. Navjot I am giving it a try. Thanks for your advice
JhonCena is offline
- by Krow
