Old 10-02-2007, 08:22 PM   #1 (permalink)
vinit suri's Avatar
Question burn iso on pen drive
can ne one here tell me how to burn an bootable iso file onto a pen drive????
vinit suri is offline
Old 10-02-2007, 09:07 PM   #2 (permalink)
Still Shining!
Lucky_star's Avatar
Default Re: burn iso on pen drive
Burning is a term associated with optical media, not pen drives. What you can do here is to create a Virtual Cd drive, load your iso file in to that, and copy the contents from that image to the PD.
Nokia N86 8MP
Lucky_star is offline
Old 10-02-2007, 10:36 PM   #3 (permalink)
Google Bot
Pathik's Avatar
does ur mobo support booting from pen drives???? if no then u cant boot 4m it even if u succeed in burning it... for non bootable ones jus extract the contents and copy them to ur pen drive...
Pathik is offline
Old 11-02-2007, 12:24 AM   #4 (permalink)
hansraj's Avatar
i dont think if u have a bootable image u can copy the bootable files from it.... what i know is the files needed for boot up are not shown in the virtual drive too... you will end up copying all the files other than the ones responsible for booting up...
hansraj is offline
Old 11-02-2007, 12:27 AM   #5 (permalink)
Google Bot
Pathik's Avatar
yup dats rite.. U can directly burn the images to make bootable cds
Pathik is offline
Old 11-02-2007, 12:44 AM   #6 (permalink)
Still Shining!
Lucky_star's Avatar
^^Yah, I doubted that too, but I thought it would work...
@Hansraj, that avatar you have is nice. If I am rite, is it from the movie Spirit-Stallion of Cimarron? Its one of my favourites
Nokia N86 8MP
Old 11-02-2007, 04:56 AM   #7 (permalink)
I Always Prefer 1080p
techtronic's Avatar
The movie is a benchmark for animation movies
techtronic is offline
Old 11-02-2007, 09:02 AM   #8 (permalink)
1337 |)00|) \m/
kaustav_geek's Avatar
IMHO... If its a linux boot .iso 1mag3 then ,it'll boot even if just the iso image is copied to the pendrive... Am not totally sure though..
Try it to check whether it actualy works...
My Blog : www.vatsuak.blogspot.com
My DA page : www.burningsilver.deviantart.com
OK..ok..... Ads are bad.. ;)
kaustav_geek is offline
Old 11-02-2007, 11:36 AM   #9 (permalink)
Google Bot
Pathik's Avatar
nope it wont work...
Pathik is offline
Old 11-02-2007, 02:26 PM   #10 (permalink)
hansraj's Avatar
thanks to all.... even i liked this movie... and more so the dvd menu... its so lovely that i only keep changing the options on the menu sometimes...
even iam working on the same subject... how to get the iso images on the pendrive ... as i dont want to waste even a single cd ... its more of a challenge for me than being a matter of using the cd..
hansraj is offline
Old 11-02-2007, 06:15 PM   #11 (permalink)
1337 |)00|) \m/
I guess this helps...
http://www.pendrivelinux.com/categor...n-a-usb-stick/
Will keep you posted for more later..
cheers.
rep me if this was helpful(i know it sounds cheap, but anyway.. )
Old 11-02-2007, 10:14 PM   #12 (permalink)
vinit suri's Avatar
thanks a lot guys..............................i tried eveythin but it does not work.....ne ways thanks a lot..
IF THIS HELPS PLEASE CLICK THE BALANCE UNDER MY ID............:wink: 8-)
Old 11-02-2007, 10:25 PM   #13 (permalink)
hansraj's Avatar
there is one more way by which u can copy the contents of bootable part in the pen drive but it does not work for all kind of iso files.
if the image file on booting up loads the files in a: drive i.e. generally the win 98 or win me cd do the same thing... then u can copy the files from A:/ to your hard disk and then again start u r os and copy those files to your pen drive with the other available folders on the image file.
But this method works only if the booting up uses the emulation and A:/ is used by it while booting up from the cd.
by the way what image file do you have n u want to copy??
hansraj is offline
Old 10-09-2009, 11:27 AM   #14 (permalink)
In fact, you can dorectly burn iso to dvd disc to play on your home dvd player, it's very converience
waterfly99 is offline
Old 10-09-2009, 08:56 PM   #15 (permalink)
1. Download and install UltraISO trial.
2. Plug in your pen drive.
3. Open UltraISO as Administrator (right-click shortcut, "Run as Administrator")
4. Open the CD/DVD image file you want to write to pendrive in this instance of UltraISO (File>Open).
5. Under the Bootable menu, select Write Disk Image.
6. A new dialog should open up, listing your pen drive(s).
7. Select the pendrive you want to write your image to.
8. Set the Write Method to USB-HDD (or USB-HDD+ if your BIOS supports it).
9. Click the Write button, and then click Yes/OK in the warning dialog (All data on this drive will be destroyed ....... do you want to continue) that pops up.
8. Sit back, relax and enjoy a drink.
pillainp is offline
- by Krow
