Old 10-02-2007, 07:25 PM   #1 (permalink)
Šupər♂ - 超人
koolbluez's Avatar
Lightbulb Is it a DIGIT cookie or...
A double-click on a zero-reply post made by the author (here.. me)helps the author change it directly @ the post list!!!
Well.. didn't get it? A picture is worth a thousand words... So have a look @ the pic.. it might enlighten u.
That is a list of new posts... I just double clicked my then 0-reply post, More Gadgets, and a field appeared with the post name editable! Check the pic out...
koolbluez is offline
Old 10-02-2007, 07:29 PM   #2 (permalink)
The Devil
blackpearl's Avatar
Default Re: Is it a DIGIT cookie or...
Can you explain a bit? I can't understand.
blackpearl is offline
Old 10-02-2007, 07:33 PM   #3 (permalink)
Arsenal_Gunners's Avatar
Dunno but I will try it.
Arsenal_Gunners is online now
Old 10-02-2007, 07:46 PM   #4 (permalink)
Distinguished Member
anandk's Avatar
it didnt work for me. maybe if its a recent 0-post one it works ?!?
> www.TheWindowsClub.com <
= www.WinVistaClub.com =
Microsoft® MVP
anandk is offline
Old 10-02-2007, 07:48 PM   #5 (permalink)
^^Yes,It will only work when it is 0 posts and nobody has seen it(I think so)
Old 10-02-2007, 07:56 PM   #6 (permalink)
nishant_nms's Avatar
nice thing even if it is a bug
nishant_nms is offline
Old 10-02-2007, 08:26 PM   #7 (permalink)
Šupər♂ - 超人
koolbluez's Avatar
Dunno.. but i thought only I was the one ignorant of it...
Well, as it turns out... I'm not the only one.. gee...
Kya yaar... Vimal... ab tu Troll ban gaya?!?
Old 10-02-2007, 08:39 PM   #8 (permalink)
Host4Cheap.org
Sukhdeep Singh's Avatar
No its not a bug. Its a feature to quickly edit Topic titles in IPB and Vbulletin. Dunno about phpBB
http://www.host4cheap.org/
Sukhdeep Singh is offline
Old 10-02-2007, 10:41 PM   #9 (permalink)
Šupər♂ - 超人
koolbluez's Avatar
what u said might b right dude... this is for ease of use... but many of us were unaware about it.
Another tip about it, guyz. Dont d-clik on the link, d-clik in the cell of the link... not on the link. If u dclik the link, u'll b directed to the link... a little l8... but near the link dclik wont take us there.
Not a bug... Nice kookie though..
Old 10-02-2007, 11:59 PM   #10 (permalink)
champ_rock
champ_rock's Avatar
ya its not a bug
its a much sort after feature in VB and IPB.. it does not exist in phpbb and SMF..
it is primarily used for moderation so that the mod does not have to open the full topic to edit the heading..
Registered Linux user number 400618
champ_rock is offline
Old 11-02-2007, 08:38 PM   #11 (permalink)
anandk's Avatar
ok it works. good share
Microsoft® MVP
anandk is offline
Old 11-02-2007, 09:20 PM   #12 (permalink)
Resident Fanatic
Manshahia's Avatar
Wow. Cool
Manshahia is offline
- by Krow
