21-01-2005, 12:56 AM
VCDCutter alternative
Is there any other software which can act as an alternative to VCDCutter.Something that can be used to make clips from VCD,join it,split it etc...
Please help...
In just two days, tomorrow will be yesterday.
21-01-2005, 01:40 AM
VCD cutter is the best!
U can do all with it within secs..... cut, join, split!
ALL!
Ish Karo... Ishq karna Tumhara Paidaishi Haq Hai........
Magar Kyon Na Is Bar Watan Ki Mitti Ko Mashuka bana le!!!
:) http://www.aseemn.org
21-01-2005, 10:33 AM
The Best Alternative Would Be BoliSoft's AVI/MPEG/ASF/WMV Splitter
Try It Out 8) Here's The Link http://www.boilsoft.com/videosplitter/
21-01-2005, 10:41 AM
Hmm.. well i use MovieMaker that comes wid XP.. its quite good..
21-01-2005, 05:56 PM
Šupər♂ - 超人
1st of all... VCD Clipper just CLIPS... not joins...
If u just want to cut... there's Easy Video Splitter
Go 4 Advanced X Video Converter, Power Video Converter, Video Edit Magic, VirtualDub
22-01-2005, 05:08 PM
Virtual Dub is good.
Also look in the Digit DVD's, coz a few months ago, Ulead DVD Studio was included in it.
Walk on the Wild Side. The other side SUX!!!
22-01-2005, 09:33 PM
VCD clipper.
Lovedeep Wadhwa
22-01-2005, 11:38 PM
Ultra Video Splitter for splitting and Ultra Video Joiner for joining files.
Some other tools available are VCDPro from 3MBTech and VCDCutPro which is an upgraded version of VCD Cutter.
But Ultra Video Splitter and Joiner support more formats than any other tools.
Features of Ultra Video Joiner:-
Joints or merge video files to a large one.
Support large video file, even large then 2GB
Very fast and without any quality loss.
Very User-friendly interface
Supports AVI(Divx,XviD,MPEG4...), MPEG1, MPEG2, DVD(.VOB), VCD(.DAT), ASF/WMV
Supports RealMedia(.RM, .RMVB)
All supported formats to MPEG1
All supported formats to MPEG2
All supported formats to VCD,SVCD,DVD(PAL,NTSC)
All supported formats to AVI(DivX,XviD, MPEG-4)
All supported formats to Windows Media Format (WMV/ASF)
Features of Ultra Video Splitter:-
Split,cut or trim large video file into smaller clips
http://swatrant.blogspot.com/
23-01-2005, 12:51 PM
hey divx codec comes handy with virtual dub
Search this Thread |
