Old 09-02-2007, 04:42 PM   #1 (permalink)
Mclaren F1 Long tail
aneesh kalra's Avatar
Default volume adjustment
What is the difference between adjusting the volume through the media player and adjusting it through the volume control knob on your speakers.Which is more prefferable max o volume on speakers or media player.
Computers are like air conditioners. They work fine until you start opening windows.
aneesh kalra is offline
Old 09-02-2007, 04:49 PM   #2 (permalink)
Host4Cheap.org
Sukhdeep Singh's Avatar
Default Re: volume adjustment
One is System Wide Volume Setting
Other is Media Player Limited Volume Setting
http://www.host4cheap.org/
Sukhdeep Singh is offline
Old 09-02-2007, 05:01 PM   #3 (permalink)
Kiran.dks's Avatar
Media Player Volume controls the volume to your headphone/speaker port. This is nothing but input signal strength to the Speakers. I suggest you to keep the volume in Media Player to around 60%. Too much high Volume as a input to Speaker may create distorted sound (like Distorting Bass or Treble). Then adjust the knob in the speaker to your desired volume.
Kiran Kumar R
Kiran.dks is offline
Old 09-02-2007, 09:19 PM   #4 (permalink)
Yes but can you also tell how input signal amplification done by the soundcard differs from that done by the speaker's amplifier because like if I have a better sound card would improve the volume i.e quantity or its quality.
Old 09-02-2007, 10:42 PM   #5 (permalink)
nishant_nms's Avatar
^^A better soundcard will cause better quality sound
nishant_nms is offline
Old 10-02-2007, 12:40 AM   #6 (permalink)
shantanu's Avatar
media player controls the sound output provided to it by sound card driver, but the vol. control is the master control for hardware sound generation..
shantanu is offline
Old 10-02-2007, 07:59 AM   #7 (permalink)
Kiran.dks's Avatar
One can't compare the amplication of a preamplifier (sound card in this scenario) with that of Amplifier (Hi-Fi set). External Speaker system's amplifier is a power house generating high outputs. This output quality depends upon input signal quality and it's amplifier board.
There is a threshold limit of its input signal strength. Beyond this strength, the quality decreases and you end up getting distorted sound. Sometimes it may damage IC's in the amplifier. Preamplification signal strength should be at optimum level, generally 60-70% range.
Kiran Kumar R
- by Krow
