Old 09-02-2007, 02:58 PM   #1 (permalink)
Default lock C: partition
well i have hard drive which i have partition into 2..so i wants to lock or put password @ on of my partition which is C: is there any application for it or ways lock it?
newbies is offline
Old 09-02-2007, 02:59 PM   #2 (permalink)
Super Hero - Super Powers
n2casey's Avatar
Default Re: lock C: partition
I u have ur windows on C: then u can't lock it.
Minds are like Parachutes :arrow: They work best when open
n2casey is offline
Old 09-02-2007, 03:28 PM   #3 (permalink)
s,b+..u cn..
nikhil ramteke's Avatar
Gving password to the drive is not known,but u can do the same thing using the following trick....
go to run,type regedit,and follow the following path
-hkey_current_user
-software
-microsoft
-windows
-current version
-policies
-explorer(double click)
then on right side panal,right cilck,then from new choose DWORD value,rename it as NoDrives,double click it,choose decimal value,and put the values for respecitve drive.(A=0,B=2,C=4,D=8,E=16,F=32............),now restart the computer,ur drive will b hidden,but if u will specify the path in the address bar then it will b visible to the user,now the thing is that u have to set this as invisible to the user,then follow the same path,again choose DWORD value,now rename it as NoViewOnDrive and again specify the value for it with decimal as a base,now again restart the computer,now even if u will b providing the path,ur administrarive setting will not allow to view the contains of the file,
if u wants to access the information from the drive then set the value data to b 0,and enjoy the security...........
__________
ok sir,then can we give password to the another drives in which our system is not there?
Last edited by nikhil ramteke; 09-02-2007 at 03:28 PM. Reason: Automerged Doublepost
nikhil ramteke is offline
Old 09-02-2007, 04:36 PM   #4 (permalink)
n2casey's Avatar
Cool Re: lock C: partition
Yes, u can use third part s/w to lock these drives. Use these
Easy Drive Lock (rar)
WinGuard Pro 2007
n2casey is offline
Old 09-02-2007, 09:19 PM   #5 (permalink)
Microsoft MVP
Vishal Gupta's Avatar
U can lock the drive using registry trick, given here:
TUTORIAL: All Kinds of Restrictions for Windows XP/2003
:arrow: http://www.AskVG.com/
Vishal Gupta is offline
Old 09-02-2007, 09:41 PM   #6 (permalink)
thanks all for the information....
newbies is offline
- by Krow
