Old 09-02-2007, 12:50 PM   #1 (permalink)
linardni's Avatar
Default System hangs..help
Whenever I try to connect to the Internet through dial up connection of my PC running Win-XP (SP2) the system hangs. Only after several trial, net can be connected. Plz help
linardni is offline
Old 09-02-2007, 12:58 PM   #2 (permalink)
Google Bot
Pathik's Avatar
Default Re: System hangs..help
scan ur system wit a antivirus... do u hav a firewall installed??
Pathik is offline
Old 09-02-2007, 01:02 PM   #3 (permalink)
HELP AND SUPPORT
rakeshishere's Avatar
Must be some Problem with ur PC Being affected by virus/spyware..Use any nice AV/Anti-spyware to have a clean scan of ur PC...and also check for any registry errors!
rakeshishere is offline
Old 10-02-2007, 03:59 PM   #4 (permalink)
Ankur Mittal's Avatar
Post about the specifications about your system,then only we can help.Maybe your RAM may be less or some modem problem.
http://ankurmittal.com
http://ankurmittal.net
Ankur Mittal is offline
- by Krow
