Old 09-02-2007, 12:48 PM   #1 (permalink)
Unhappy ctrl+alt+del=task manager disabled
i have windows xp media center edition sp2 with single user,whenever i tried to open task manager ctrl+alt+del a error show that task manager has been disabled by your administrator but i am the administrator user. how can i open the task manager?
gaurav816 is offline
Old 09-02-2007, 01:00 PM   #2 (permalink)
HELP AND SUPPORT
rakeshishere's Avatar
Default Re: ctrl+alt+del=task manager disabled
Clean ur Pc with any good AV and Anti-spyware!
rakeshishere is offline
Old 09-02-2007, 01:13 PM   #3 (permalink)
i am using zone alarm pro with regular update & norton internet security but the problem is not solved
Old 09-02-2007, 01:19 PM   #4 (permalink)
HELP AND SUPPORT
http://windowsxp.mvps.org/Taskmanager_error.htm
Hope This Solves!
Old 09-02-2007, 01:22 PM   #5 (permalink)
Distinguished Member
anandk's Avatar
Taskbar Repair Tool Plus!
> www.TheWindowsClub.com <
= www.WinVistaClub.com =
Microsoft® MVP
anandk is offline
Old 09-02-2007, 02:29 PM   #6 (permalink)
whoopy_whale's Avatar
Download and run this REG fix and double-click it.
http://windowsxp.mvps.org/reg/EnableTM.reg
In just two days, tomorrow will be yesterday.
whoopy_whale is offline
Old 09-02-2007, 03:38 PM   #7 (permalink)
s,b+..u cn..
nikhil ramteke's Avatar
try this...........
go to run,type gpedit.msc, then go through following path
-local computer plociy
-user configurtion
-administrative templets
-system
-alt+cntrl+delete option(double click)
then on right side panal,double click the text--Remove Task Manager,set its value to Disable or Not Configured,and probably restart the computer.....
nikhil ramteke is offline
Old 10-02-2007, 01:23 PM   #8 (permalink)
thanks to all of you my friends gpedit.msc works thanks again
Old 14-02-2007, 04:47 PM   #9 (permalink)
s,b+..u cn..
again u can work in regedit also,u can have various funtion or utilities in this,but keep in mind that it is engine of ur system,dont spoil it,do know about this and then work in it.....
- by Krow
