Old 09-02-2007, 08:57 AM   #1 (permalink)
gdatuk's Avatar
Default Help in installing a setup file
I want to install a setup.exe file. But i dont have write access to the C: drive. I usually install programs in the D: drive. But this specific setup doesnt even give me the option to select the drive and folder. By default it tries to install itself in the C:. Is there any way to bypass and install it in D:.
p.s: I dont have admin rights for the pc
Twitter @cgiridhar
Moto Milestone | Rooted | Froyo | CM 6.1.0
AMD Phenom2 720 x3 BE | Gigabyte MA78G | WD 500Gb+Seagate 1TB ext | PSU Corsair vx450 | Corsair 2x2gb RAM | Bose Companion 5
gdatuk is offline
Old 09-02-2007, 07:00 PM   #2 (permalink)
Chetan1991's Avatar
Default Re: Help in installing a setup file
I'm not sure but you should try this method once:
When log on screen appears, press "Ctrl+Alt+Del" twice and you will see a dialog box.type "Administration" as User and proceed.Then you may be able to work as an administrator.
If you like my reply and it works,PLS repute me
Chetan1991 is online now
Old 09-02-2007, 07:20 PM   #3 (permalink)
HELP AND SUPPORT
rakeshishere's Avatar
It might be an application which basically stores its settings in windows directory and needs an entry in to the registry so U have to install in C drive
rakeshishere is offline
- by Krow
