Old 09-02-2007, 02:25 AM   #1 (permalink)
Exclamation Plsss help..Which 1 is better????
Hi frnds,
I hve Intel Chipset 845GV Motherboard...n intel P4 2.66 GHz Processor,,,,
I wana to know Which 1 is better regarding performance????---256 DDR @400 MHz Frequency RAM or 384 DDR @266 MHz(128DDR @266MHz + 256DDR @ 266MHz) RAM.....
plsssss help me out......which 1 frm the above is better regarding performance???
Wa8ing 4 ur help...
Regards,
Deepak
dipak15 is offline
Old 09-02-2007, 02:28 AM   #2 (permalink)
Arsenal_Gunners's Avatar
Default Re: Plsss help..Which 1 is better????
Plsss dont repeat threads.Reported
Plss help...Which 1 is better???
Arsenal_Gunners is online now
Old 09-02-2007, 02:35 AM   #3 (permalink)
Hey I hven't repeated...that is in another section of forum
dipak15 is offline
Old 09-02-2007, 02:38 AM   #4 (permalink)
1.Repeat is a repeat.
2.The section is wrong.
Please don't repeat your posts,it is breach of forum rules
Old 09-02-2007, 07:52 AM   #5 (permalink)
Tux Fan
shaunak's Avatar
Still lemme answer your query:
First calculate the bandwidth of you RAM
You just take the the speed the RAM is clocked at, double it then multiply by 8. And if you're running dual channel mode, you double it again.
DDR-200: DDR-SDRAM memory chips specified to operate at 100 MHz
DDR-266: DDR-SDRAM memory chips specified to operate at 133 MHz
DDR-333: DDR-SDRAM memory chips specified to operate at 166 MHz
DDR-400: DDR-SDRAM memory chips specified to operate at 200 MHz
Bandwidth basically means how much data [1 & 0s'] can be crammed in simultaneously by you OS. Greater the bandwidth better the performance [less chances of hanging/lagging]
But on the filp you will run out of memory sooner due to the smaller capacity.
[Think of this as a pipline and a tank, no use of a bigger pipe if the tank is full.]
If you:
> do video editing or use any other resource heavy application [3d editing, cad, simulators] in which a little "lag" is tolerable, go for greater ammount of memory.
>for performance, gamming and future upgradibility's sake go for greater bandwidth.
Cheers
Shaunak
Feel free to PM/email me.
shaunak is offline
Old 09-02-2007, 02:10 PM   #6 (permalink)
Exclamation Re: Plsss help..Which 1 is better????
Thanx Shaunak
Actually scenerio is dat I already hve both 128 @266MHz and 256 @ 266MHz...n using both of them 4 last 1 yr...but now my 256 @ 266MHz crashed..... n it is in warranty period....so i can get a replacement 4 it...
So plss help dat whether now i ask my dealer to replace it as 256 DDR @ 266 or 400 MHz.....also i dont think so 256 wid 266MHz come in the market....so by deafault i think my dealer gimme a 256 @ 400MHz RAM....I think so........
So dats y asking which 1 to get frm my dealer 256 DDR @ 266MHz or 256 DDR @ 400MHz.......In case if i 'll get 256 DDR @ 400MHz ,,,,i think my 128 DDR @266MHz...may go to junk yard...as i dont thing 2 RAM's wid diff frequency work together......
So help me frnds finally which 1 to opt??????
Wa8ing
Regard's
Deepak
dipak15 is offline
Old 09-02-2007, 02:54 PM   #7 (permalink)
Google Bot
Pathik's Avatar
get a 256mb ddr 400mhz
Pathik is offline
Old 09-02-2007, 02:57 PM   #8 (permalink)
^Short and accurate
- by Krow
