09-02-2007, 01:52 AM
mental ray topics :-)
hi , i wanted to explore mentalray a lot  . posting this in a belief that people will help me get to this wonderful render  . please cover mental ray lights , materials , HDRI.  saurav . . please help
Make a day good , and another day good , and another ...a happy lad is "born" from you :)
09-02-2007, 02:18 AM
You gave been GXified
Re: mental ray topics :-)
Well....first of all, go to cgtalk.com for mental ray or evermotion.org for Vray tutorials & basics
Mental ray depends compleately on the dimensions you use to make your scene, like i use centimters in the viewport & system of 3Ds Max, however, if u don't like i did ones, my scene was actully 15km in length, & photons were not showing at all. So first, make it a habit to model in correct dimensions. they should really bundle an optical physics book with mental ray
2nd, start with basic lights....I use the 3 point light setup, one key light, one fill light, & back light...
3rd, i will post tomorrow, right now going to sleep
about.me/gxsaurav
09-02-2007, 02:21 AM
MINISHA LAMBA
09-02-2007, 02:35 AM
oh vimal  . . . it wont do the trick now for him  . . well i have been looking at cgtalk for a couple of months  . but only for ref models . will look for mental ray tomorrow  . hey give me some good links  . thanks buddy
09-02-2007, 02:40 AM
Originally Posted by vimal_mehrotra
MINISHA LAMBA
What who where
 she isn't here....damn you vimal
about.me/gxsaurav
09-02-2007, 02:41 AM
See it did the trick
she was here when you left but now she is gone
10-02-2007, 02:14 AM
 . .  . . ok mate i am waiting for tut tomorrow . dont fail
__________
help me here please
Reason: Automerged Doublepost
10-02-2007, 02:23 AM
Sorry, was away
rajasekharan, you do one thing. Since there are two types of rednering & I m not familier with Maya anymore, i m telling u the method, you try that in your scenes, & see for yourself how it works. Use Maya 8 or 8.5 as they have Mray 3.5. I can tell u exectly everything in 3ds Max but not maya. You are better off visiting some threads on cgtalk.com for maya
1) Exterior scene
1 key light, mr area spot. This is the main shadow casting light, just apply this with no FG & GI, & position it according to the Shadow direction you want
Now, add one skylight to it, the normal one in maya, enable FG & go with draft profile with 2 FG bounce, render it...show it here, how it renders
about.me/gxsaurav
10-02-2007, 02:40 AM
hey , thanks for it . . i am half way through with maya . been swinging between max and maya  . the thing is how to fake a sky light in maya .  i dont see a sky light there  .
__________
well i use 3 point light , thats ok . . but did you look at the gnomon videos . the way they have done SSS thats what i fail to get    . and ofcourse the HDRI effect that vray gives me . i cant replicate it in mental ray
10-02-2007, 02:45 AM
Well, i can tell u about max but no exp in maya now.
In 3ds max we have a "skylight", which u can create using create light control panel. Or u can use the mental ray 3.5 mr sky & mr sun, these should be in Maya too. There should be a skylight in maya too...check somewhere
I didn't see the gnomon videos....was not able to download them...do u have it?well, can u courier me the mental ray lightning & rendering dvd is possible?
to use SSS with mental ray, i simply use the SSS materials already given, add a key light & then modify the materials. It works mostly, confession : I suck in charectar modeling
about.me/gxsaurav
10-02-2007, 02:56 AM
you want some . .  . i have 4dvds of tute collected in my home . i will give you this month end when i go home  . i have 4 gnomon cds with me . ripped ones . i have compiled to a dvd . will send you tomorrow eve or max by monday if you give me your address  .
__________
do you have any tute with you  . i can send all my video tute to you less than 10 dvd i guess  . i need lighting tutees  . i am more interested in materials and lighting stuffs animation is not my thing . i suck there  . modeling , well i am trying and is progressing well . now doing all with edge extrude  .
10-02-2007, 08:08 AM
i already have it , but thanks for that link . . its from their site i have learned vray  . i have that tute saved  . but i really appreciate your effort to help me here  . well done mate . i cant rep you as i am low on rep  . but hey, i can thank you  .
12-02-2007, 01:35 AM
hey , no problem , man............. its that am also into this field and its my career ........... is it ur career too???
Search this Thread |
