Old 09-02-2007, 12:15 AM   #1 (permalink)
The Devil's Advocate
iMav's Avatar
Default Complete Automation
Is there a way by which i make a cd which will format, install XP (tut already present ... i know), office, and other imp softwares as wished by me and also patch em or fill in the serial frm a file
http://beingmanan.com
iMav is offline
Old 09-02-2007, 12:19 AM   #2 (permalink)
Google Bot
Pathik's Avatar
Default Re: Complete Automation
i dont think so
Pathik is offline
Old 09-02-2007, 12:24 AM   #3 (permalink)
You gave been GXified
gxsaurav's Avatar
use nlite, u can do everything other then the format part, that has to be user based
Since you wnat to install office too, it won't be a CD, it will be a DVD
about.me/gxsaurav
gxsaurav is offline
Old 09-02-2007, 12:24 AM   #4 (permalink)
HELP AND SUPPORT
rakeshishere's Avatar
USe NLite to Make a Custom Install CD/DVD of ur OS and Make an answer File for Unattended installation of XP
*PS-Rep me If my Post Hlpd U
NOTE:The Post of gx_saurav and mine are Posted almost at the same Time:12:24am
rakeshishere is offline
Old 09-02-2007, 12:28 AM   #5 (permalink)
Google Bot
Pathik's Avatar
@gx wat abt the auto serial entering thingy?
Pathik is offline
Old 09-02-2007, 12:32 AM   #6 (permalink)
HELP AND SUPPORT
Make an answer file for xp installation using nLite where the serial needs to be entered so that it doesnt prompt for it during automated installation!
Old 09-02-2007, 12:35 AM   #7 (permalink)
Microsoft MVP
Vishal Gupta's Avatar
Automation, integrating updates, derivers, etc can be done using "nLite".
And regarding to the integrating softwares, like office, etc. U'll need a DVD and u can follow the "Unattended msfn" link given by rakesh.
:arrow: http://www.AskVG.com/
Vishal Gupta is offline
Old 09-02-2007, 01:39 AM   #8 (permalink)
HELP AND SUPPORT
Even Windows Unattended CD Creator can be used instead of Nlite though it has very less options and has easy to use interface
Old 09-02-2007, 08:09 PM   #9 (permalink)
iMav's Avatar
thank u guys ...
iMav is offline
- by Krow
