When i switch ON the main power, the system automatically starts. But there is no display and no beep. I tried changing the ram slots, cleared cmos settings. But it still does not work.
I use Pentium 4 1.7 GHz
512 RAM
80 GB HDD
845G motherboard
Waiting for reply
^^After this the problem started?Hmm...If it is a ram problem there must be a beep.
Tighten all the power connectors on the motherboard,it looks like power problem.
-first of all remove the connection of ur start and restart button on cpu,and again reconnetct them properly,now remove the cmos battery and jumper beside of that....
