08-02-2007, 12:01 AM
a_g = JPKN
Locking Up a Drive
hey guys help me.
i've very imp. datas- games, game mods, s/w Install files... on F: drive,
i want to safegaurd me PC (partition) from getting affected by Virus/spyware...
i cant make back-up (~20GB of files)
i'm goin to chennai, so my PC will be helpless here.
when i'm gone my bro's frnd are coming over, they're all kinda use the net for ONLY porn purpose   or Yahoo chat  , & they're Illiterates (not my bro)  when it comes to Virus/trojans. add UL900 broadband to it, & i'll have a ZOMBIE PC when i come back.
O.S. i'm using-
=>Vista beta2 (no AV work, as its a beta)
currentlyusin web for just thinkdigit, rediffmail, google. tats all
as far as OS drive (17.5GB) i'm not worried about it, as i'll be formatting it for XP SP2
me main concern is F: Drive (25GB).
so suggest me a s/w or hack which'll be easy to use & it should not be a problm to unlock that drive when i format C: drive.
ASUS K53SV SX520D + BF3
08-02-2007, 12:04 AM
Re: Locking Up a Drive
Hmm....Not exactly a "Zombie" pc  .Use a parental control software to stop porn(it will be immoral though   ) use this http://www.ie101.com/download/Anti-Porn.EXE
(test it yourself first  .It is also anti-chat)
shareware for 30 days.
08-02-2007, 12:16 AM
a_g = JPKN
08-02-2007, 12:19 AM
lock the drive , aye ?????
why don't just got to computer management and remove the drive ???
or simply deny all rights to the drive via security tab ???
08-02-2007, 12:22 AM
Yeah..I think there is an inbuilt feature like this in Vista.
08-02-2007, 12:32 AM
a_g = JPKN
its BETA dude, i dont wanna take any risk with it.
u know, when i resume the PC from Sleep mode, the AUDIO dont work  , e.g. in Media Player11, it happens every time
08-02-2007, 12:33 AM
So use the software!
08-02-2007, 12:35 AM
a_g = JPKN
which one?
any Drive Lockers for Vista.
08-02-2007, 12:36 AM
In post 2
So you want boys to watch porn but don't download viruses eh?hmm
08-02-2007, 12:37 AM
a_g = JPKN
Yup
08-02-2007, 12:43 AM
GUNNING DOWN TEAMS
Originally Posted by s18000rpm
which one?
will be hard to get lockers for vista...that too beta...
reinstall XP and use this
winguard pro
08-02-2007, 12:47 AM
vista beta has nothing to do with it if u have that drive with NTFS system and u r the admin than u can deny permission to nyone for any file/folder/drive. only admin can alter that permission.
and if u don't have NTFS file system in that drive and u don't want to convert it to one either then just follow: control panel >> admin tools >> comp. mgt. >> disk mgt. >> rt clk the drive >> change drive letter n path >> remove the drive letter or any other mount pt. the drive is now inaccessible to this OS.
08-02-2007, 02:17 AM
Super Hero - Super Powers
Originally Posted by Vishal Gupta
But Vishal he want a restriction for viruses too.
Registry trick can't help for that.
Minds are like Parachutes :arrow: They work best when open
08-02-2007, 02:21 AM
the only way is to block the "potentially threatening" sites
08-02-2007, 02:25 AM
Microsoft MVP
@n2casey
The trick will do the job coz after using the trick, the drive will be inaccessible. So no virus problem!
08-02-2007, 02:53 AM
Noobie Pro
Why dont you create a New User Account for them, and Block that Accounts access to this drive using the Security settings.
Its there in XP, so its bound to be there in Vista, Hoping it is a NTFS drive.
www.twitter.com/alsiladka
08-02-2007, 08:14 AM
Still Shining!
Why Don't you use Folder lock and Lock down the whole drive?
It would be the best option in my opinion?
Nokia N86 8MP
08-02-2007, 09:05 AM
#19 (permalink)
I suggest you to lock the drive with a third party tool making it totally inaccesible. Even if the system is infected with malware, still it can't get into the locked drive. You are absolutely safe.
Download: Easy Drive Lock (rar) from sunXvogy Studio
Size: 166KB | Date: Jan 2007 | System Requirements: Windows NT/2000/XP/2003 Server/Vista | License:10-use trial
More Info: Click here
Kiran Kumar R
08-02-2007, 12:17 PM
#20 (permalink)
You can hide any of drive(s) by just adding two keys in windows registry
goto start>run
Type regedit and press enter. This will bring you to the registry editor.To hide any drive you have to follow these 2 steps
STEP1: Hidding Drive
goto HKEY_CURRENT_USER\Software\Microsoft\Windows\Curre ntVersion\Policies\Explorer now create a new DWORD value NoDrives and set its value as
2^(Alpha Number of Drive Letter-1)
where Alpha number are simple counting of alphabets from A to Z as 1 - 26
for example: to hide C drive
Alpha number of C is 3 so 2^(3-1) = 4 (decimal value)
If you want to hide more than one drive than calculate the value of each drive as explained and then set sum of those numbers as value
Step2: Prevent Access to the drive
Now as we have make our drive invisbble but it is still accesible so to lock the drive we will create another DWORD value at
create a new DWORD value NoViewOnDrive and set its value same as you have calculated for hidding the drive(s)
Now your drive is locked. If you want to unlock and unhidden the drive then just delete these two keys and your drive is again accessible. You can also create two .reg files one for hidding and locking and another one for unlocking and unhidding
source
__________
Buddy folder lock can be broken by kids.My bro told me how to do it last year.
Visit now ;)
www.indiandevs.com - for great free designs :)
www.indiandevs.com/technoworld/ for latest technology news and tricks
Reason: Automerged Doublepost
08-02-2007, 02:11 PM
#21 (permalink)
a_g = JPKN
ok guys, i'll try the registry way.
btw @kiran, i d/led tat s/w & locked a drive with password, ut it was accessible & when i tried to unlock, it gave Wrong psswrd error.
tho the drive was not locked & was accessible.
ok gotta go, catch the train
08-02-2007, 02:14 PM
#22 (permalink)
What are you doing here,your train is on 2:30 right?apply the regheck carefully or the boys will not have an os to watch porn
08-02-2007, 02:15 PM
#23 (permalink)
a_g = JPKN
08-02-2007, 02:16 PM
#24 (permalink)
Oh nooo.I really wanted to be there,I am a "F" series fanboy.That is a cool F-16 right
08-02-2007, 03:56 PM
#25 (permalink)
hi
make a new user for them giving the permission ,in "limited".
so that they can't make ,and then fallow this .
For more info in DeepFreeze visit the given link
Deep Freeze-Standard Bulletproof Disk Protection
this option i got yesterday .
i think it is good for u .
08-02-2007, 09:16 PM
#26 (permalink)
a_g = JPKN
too late dudes
i've applied the reg. hack & didnt even had time to check it
when i was on train my bro called & asked why doesnt any DVD work
dunno WTF is the reason    even gmail, yahoo was notworking they said, but just before leaving house i was checking my G-MAIL
i just hope that the DRIVE can be unlocked  without any Struggle
@Vimal yup tats a F-16.
man they were doin so much of Stunts, i mean the USAF were the KING there.
this F-16 did a fly-by & frm 150 meters (height) it went to 5 KILOMETERS Straight Up
my thoughts @ tat time was- "F@cK wat the hell did he do just now", tat guy came back, aligned to Runway & did fu#kin 3 Barrel Rolls    & took a f@ckin SHARP turn like heLL.
took Video of those Stunts, i'll definetly upload them
08-02-2007, 10:02 PM
#27 (permalink)
yeah sure  .USAF rocks
Search this Thread |
