Old 07-02-2007, 01:24 PM   #1 (permalink)
Kiran.dks's Avatar
Arrow UPDATE: Ashampoo® Burning Studio 6.50 Released.
Easy to use Burning tool
Manufacturers Description:
The new Ashampoo Burning Studio 6 keeps all the advantages of its predecessor and adds multi-disc file backup, an integrated audio CD ripper and further improved support for the exciting new Blu-ray format with capacities of up to 25 gigabytes per layer.
Many users are tired of over-complicated CD burning applications that are getting harder and harder to use. Sometimes you can waste most of your time just trying to find a function. Ashampoo Burning Studio focuses on what you want: To burn discs quickly, easily, with maximum quality and minimum hassle. It includes everything you need to be able to do that. And it excludes everything that could get in the way.
What’s new:
  • Multi-disc file backup and restore on CDs, DVDs and Blu-ray discs
  • Create compressed backup archives with powerful password protection
  • Split archives automatically across multiple CDs, DVDs or Blu-ray discs
  • Restore archive contents to their original locations
  • Integrated Audio CD ripper – store your audio tracks as WMA or WAV files
  • New option for setting the number of copies you want to burn (available for all disc formats)
  • Discs can now be verified immediately without being ejected first (if the drive supports this feature)
  • Numerous other small improvements that make the program easier to use and more effective
Download: Ashampoo® Burning Studio (Free Trial)
Home Page
Kiran Kumar R
Kiran.dks is offline
Old 07-02-2007, 04:37 PM   #2 (permalink)
I Always Prefer 1080p
techtronic's Avatar
Default Re: UPDATE: Ashampoo® Burning Studio 6.50 Released.
Thanks for the post
techtronic is offline
- by gforz
