Originally Posted by bukaida
It seems that flash is not adequate for that(it is generating in a discrete way).
Flash is adequet for everything, you just have to cause an optuical illusion!
A quick and dirty example of smoothness: [its a little stuttred as i had to upload it in gif format.]
Click here
Heres a quick and dirty how to:
> put you picture/animation in one layer
> draw a black rectangle covering the whole stage on another. [lets call it "cover"]
> move forward 30 frames and replace the black rectangle in "cover" with a grey one.
> delete all the boundries in the rectangles [the outlines]
> use shape tween between the two frames.
> you should have a faded effect.
>ps: if you know a bit of action script you can use transparancies with the _alpha syntax to achive the "vista look"
