06-02-2007, 08:47 AM
TeCh Blogger : Gtechinfo
Help to prevent hacking
hi guys, my friebds have bsnl broadband home plan 500, he told me that yesterday when he was checking his internet usage, he found a usage record in between 1pm to 2:12pm in which about 10 mb of data were transpher during that period. He is absolute sure that nobody from his computer has use the intnet during that time. plz help me out so that i could help him to prevent this type of things in futere...........
06-02-2007, 09:19 AM
Re: Help to prevent hacking
visit BSNL Portal and change password.
06-02-2007, 10:17 AM
10MB is too low to account for hacking! I guess it is some automatic updation happening. May be Windows Automatic Updates!....
Kiran Kumar R
06-02-2007, 11:58 AM
Beware of the innocent
or antivirus software updating itself.
Life is too short. Have fun.
06-02-2007, 07:11 PM
does windows update occer when moden is off? or even if the computer is switchoff
06-02-2007, 11:51 PM
Coming back to life ..
See if the modem was off how can BSNL moniter that usage ..? The modem must've been on and online ...
And I wait without you ...
With or without you ..
Batty = Too Busy Now !!!
06-02-2007, 11:55 PM
a_g = JPKN
or sumone has ur ID & passwrd
there was a discussion going in chip forum on similar issue, so change ur Passwrd to a more secure one or use a dialer to connect.
i'm on ul900 plan so no worries
ASUS K53SV SX520D + BF3
07-02-2007, 12:26 AM
The No.1 Stupid
^^whats the benefit of using a dialer to connect ???
n00b forever...
07-02-2007, 12:45 AM
a_g = JPKN
ur password is not saved on Router(modem), so ur safe
07-02-2007, 01:08 AM
The No.1 Stupid
ok , thanx.
n00b forever...
07-02-2007, 03:29 AM
AMD user for 9 yrs!!
yes its possible that someoneelse is using your account if he knows ur password!
First change your password, and then switch to Dialup Mode
(aka Bridge Mode)
07-02-2007, 08:02 PM
how would i do that, plz tell me, by doing that should i get the same speed of my broadband, as earlier.
__________
(aka Bridge Mode)
Reason: Automerged Doublepost
07-02-2007, 09:51 PM
String Phreak
Just change to a lengthy password and disable if there is an option like "remote management"!
08-02-2007, 02:36 AM
You cant expect your speed to increase, .. your speed is set by your service provider. It doesnt change.
08-02-2007, 07:11 AM
where should i get these option,
08-02-2007, 09:54 AM
Rebooting
http://10.240.43.216
is the address from where u can change the PW... just changing the PW will do... no need to worry...
rebooting
ChotoCheeta.com
08-02-2007, 09:55 AM
String Phreak
In ur router's settings!
Search this Thread |
