Old 19-01-2005, 06:39 PM   #1 (permalink)
ramprasad's Avatar
Default Unable to play VCDs
Hi all
Recently my friend burnt a VCD that plays perfectly in his system, but I am not able to play the same in my system. I have WMP 9, Power DVD... even then I am not able to play it... Is it some kinda codec problem... If so, can anyone of u let me know where I can download the latest codecs.....
Regards,
Ramprasad
ramprasad is offline
Old 19-01-2005, 08:57 PM   #2 (permalink)
Another Brick in the Wall
drgrudge's Avatar
U need to have some codec installed, for playing divx movies or .avi extensions files.
get k-lite or nimo codec pack.
Google with the keywords and u are done man.
drgrudge is offline
Old 19-01-2005, 10:20 PM   #3 (permalink)
Laptoping
Sourabh's Avatar
man this Media Player Classic with aCe mEdIa cOdEcS surely roxx
supports almost everything
these guys must have busted their a$$e$ making such a thing possible
worth trying once
download it size 44 MB tho
Sourabh is offline
Old 20-01-2005, 10:35 PM   #4 (permalink)
Šupər♂ - 超人
koolbluez's Avatar
Might not b a codec problem.. as u urselves mentioned it is a VCD.. meanin an MPEG1 file..
The problem might b with the burnin part... the CD was burnt real fast.. so some cd-readers'll have a problem readin it.. but the original writer won't have da problem readin it... So try it once more on the same writer.. usin da existin CD.. & write @ 8X... preferably make an image 1st on the HDD.. then write onto CD.
Better waste TIME than MONEY+TIME..
8X=10min... think in this way...
80min. = 1x
so... @8x = 10min.
@12x = 7min... so on
To optimally write a cd PLEASE WRITE @ 16X or lower... essentially @least 1/4th da readin speed of the drive u wanna play it on... i.e. if u wanna play on a 48X reader... write @ 48/4 = 12X speed or lower. GOT IT.....
koolbluez is offline
Old 20-01-2005, 11:12 PM   #5 (permalink)
SABER RIDER
maverickrohan's Avatar
Seriously Dude.........
Ur question is weird..........1st u say its a VCD(MPEG1)........then u talk abt not having the ri8 codecs........
Dude......if its a VCD, the problem is with ur CD-ROM or wateva.........
If its a CD with an *.avi file on it, then u do need codecs...........To know all about codecs n where to download them...........
CLICK ON THE LINK IN MY SIGNATURE............
Find out Which is The Best Video Codec?....And how to encode video the right way..!!----->>>>> http://www.thinkdigit.com/forum/showthread.php?t=3908
maverickrohan is offline
Old 13-03-2005, 02:38 PM   #6 (permalink)
ramprasad's Avatar
I have 2 .DAT files in the CD....
Regards,
Ramprasad
Old 13-03-2005, 04:19 PM   #7 (permalink)
enoonmai's Avatar
Download GSpot from here :
http://www.headbands.com/gspot/download.html
and then run it on the files to make sure they're videoCD streams in MPEG-1. It will tell you if you need a codec. Also reinstall DirectX and try using another media player to see if it plays on that.
Playing FEAR XP/LSW2
enoonmai is offline
Old 13-03-2005, 06:11 PM   #8 (permalink)
Ignorance is BLISS !!
Use some other media player mate
Use some pro stuff like Jet Audio !
It sure plays everything that u could imagine!
Well.............Almost !!!
rajkumar_personal is offline
Old 14-03-2005, 01:26 AM   #9 (permalink)
hafees's Avatar
As koolbluez said it may not be a codec problem. IF u 're sure that ur CD contains an MPEG or .dat movie then it should be playable by Mediaplayer and Power DVD. Power DVD even plays some erroneous VCDs that cant be played in Media Player. I suggest u a method. try this.
Try copying the file from the CD to the Hard disk. If it can be copied then it should be playable. Most probably it will throw u some errors. If the error occurs in the last stage only(only 10 or 20 seconds remaining)and if u're using Win 9x then hit CTRL + ALT + DEL and kill the COpying .. process. now try to play the copied file. It should work.
hafees is offline
Old 15-03-2005, 04:40 PM   #10 (permalink)
Otherwise best is use VLC media player (www.videolan.org/vlc/). Would play any avi, VCD or DVD. Its freeware.
jerry146 is offline
Old 15-03-2005, 04:47 PM   #11 (permalink)
@ ramprasad
what's the error message u r getting ??that could lead us to the sol for ur problem
C2D@ 2.4Ghz,Asus P5B Dlx,2X1GB Kingston@677 Mhz,Viewsonic 20",Sparkle 7200 GS ,SB Live Audigy on Creative Inspire T7900,Leadtek WinFast XP TV Tuner,Storage :Seagate 320GB + WD My Notebook 1TB
blacklight is offline
- by gforz
