Old 19-01-2005, 10:09 AM   #1 (permalink)
Default Yahoo Messenger,hw to copy Friend list from one id to anothr
Hi friends
i have a yahoo id , which has lots of friends ...
and now i want to use my another id ,
bur Is there any way to copy da friend list of my first id to another ??????
remember both are 2 diff. ids....
जय माता दी
It\'s Ok.... u r the best ,,,, i can speak more lie ,if u r happy with it,,, WWW.GOOGLE.COM is BIG BOSS !!!
imprince is offline
Old 19-01-2005, 10:46 AM   #2 (permalink)
I personally feel like there is no such facility provided by Yahoo!! ... as such my long experience with messenger i have never done sth like this ...
I can give U a solution send all ur list id's as offlines to other & sequentially add them up over there ?
how abt this one
At times in ur life just to do things right U have to be steady & sacrifice sth which u want the most.....even ur dreamzz tooo....
yehmeriidhain is offline
Old 19-01-2005, 11:28 AM   #3 (permalink)
Let the music play.....
djmykey's Avatar
Nopes man ur in tuff luck just sit down next to him and copy the names on a piece of paper or just somehow press the print screen button the paste it in paint, and then begin ur work.
djmykey is offline
Old 19-01-2005, 11:33 AM   #4 (permalink)
Ethan_Hunt's Avatar
Here's a Better One Just Mass PM Everybody In Ur List To Add U onto Ur New Id.......cause I Dun Suppose Yahoo Has a Deafult Freinds Importing Facility
Ethan_Hunt is offline
Old 19-01-2005, 12:02 PM   #5 (permalink)
Hmm.. Why another ID.. You can create Another PROFILE ID, and retain your buddy list, with ur new profile id.. Thats how i do..
SmoothCriminal is offline
Old 19-01-2005, 12:17 PM   #6 (permalink)
yea! i smoothcriminal is rite!!! jus create another public profile. its da best way out!
futuristically_ancient is offline
Old 19-01-2005, 12:21 PM   #7 (permalink)
h4ck3r
Posts: n/a
use yahoo messenger multiple user patch and then log on to both the ids simultaneously but still it is going to be djmykey's way thereafter..
Old 19-01-2005, 07:05 PM   #8 (permalink)
Try this if it works
Import ur Address Book form ur older id to the newer one (ur older add book should have ur friends messenger id in it)
If it dosent work in ur new ids add book add ur fiends messenger ids.
But gonna be a hurricane of task.
BEST oF LUCK
Have a Nice Day :)
Mohammed Muchhala, © 2006, All Rights Reserved
http://www.muchhalasworld.com
babumuchhala is offline
- by gforz
