Originally Posted by Ron
Query solved by arun.................
However it seems to me that ur fade up
.. from ur students as they mk useless files and change c: settings...............
Therefore i suggest u to restrict ur c: and use DeepFreeze
..as it will not only restrict ur students from changing the settings but it will also restore the data in the next restart for ur computer
For more info in DeepFreeze visit the given link
Deep Freeze-Standard Bulletproof Disk Protection
@ron
do computer administrator can change the features only?
__________
Originally Posted by sakumar79
You can restrict users from creating new users by setting it in gpedit.msc (Edit: You can also do this by making the account into Limited Account type instead of Power User or User)
You can restrict user from changing password through Computer Management(compmgmt.msc)->Users->Rightclick on user and setting property
Arun
@sakumar ,(1) i opened all keys and subkeys of user configuration , on going "gpedit.msc, but i could not get any conclusion.pl give me brief description.
(2)though i have mentioned that there is a comp.lab ,and every pc runs over win xp ,with sp -2. there is no option "properties " in the user too.
has it to be done on server? .description needs.
