Old 18-01-2005, 10:31 AM   #1 (permalink)
Default how to do multisession?
HI,
could somebody tell me how to do multisession while writing.I have samsung cd rw.I use nero 6.Is it harmful in any manner for the writer or are there chances of data loss etc.
reply awaited
kris
krisjr is offline
Old 18-01-2005, 11:16 AM   #2 (permalink)
whoopy_whale's Avatar
Creating a multisession disc with Nero is easy.Just check the option Enable multisession.I think it is checked by default.It is not harmful to the writer.Regarding to data loss,I lost my data once.I wrote 3 sessions and after the 4th, data of other 3 sessions wasn't readable.But it happened only once.And I think it happens when different speeds are used to write the data.
In case you lose your data use Isobuster to retrieve the data back.
In just two days, tomorrow will be yesterday.
whoopy_whale is offline
Old 18-01-2005, 11:50 AM   #3 (permalink)
Well just dunt bother abt losing data with Nero 6 even if U change the name of ur present session while burning ..then ur preceding data is included under the new name itself ... so just dunt bother abt losing data in Nero 6 ....
& to start a multisession disc ..just tick the option of keeping the disk as multisession ... yeah! it is enabled by default .... NO! just dunt worry! U willn't be losing ne data...
At times in ur life just to do things right U have to be steady & sacrifice sth which u want the most.....even ur dreamzz tooo....
yehmeriidhain is offline
Old 19-01-2005, 01:57 PM   #4 (permalink)
hi,
will that option come once i insert a blank cd r..cuz i didnt find it in the nero6 options,preferences button.
could u plz clarify..
Is samsung cdr good
krisjr is offline
Old 19-01-2005, 01:58 PM   #5 (permalink)
hi,
Is samsung cdr good
krisjr is offline
Old 21-01-2005, 04:10 PM   #6 (permalink)
hi
well i tried all but i never found that enable multisession man.i inserted a blank cdr but all things are opening but that enable multisession thng is no wer to be found.i use nero6.6.Could u plz elaborate mate.
krisjr is offline
Old 21-01-2005, 04:11 PM   #7 (permalink)
hi
krisjr is offline
Old 21-01-2005, 04:21 PM   #8 (permalink)
Sure man!! this is it ... check this thumbnail :
Am i clear enough now???
Old 21-01-2005, 11:44 PM   #9 (permalink)
hi,
tx mate for all that.but what i really meant was,i know its possible when ur making data cd.is multisession possible when u make other types of cd say audio,cd copy,data and audio etc.
krisjr is offline
Old 22-01-2005, 01:41 PM   #10 (permalink)
harish_21_10's Avatar
multisession is possible with every type of burning other that the audio cd's
NOBODY is PERFECT and i am NOBODY
harish_21_10 is offline
- by gforz
