Old 01-02-2007, 11:17 AM   #1 (permalink)
Unhappy spyware issue
Hi,
My internet explorer home page automatically has been changed to sex.com, unable to change to about:blank, bcz options are disable.
Somebody told me spyHunter is best tool to remove this, but it not freeware, so can't remove it.
plz help...
him007
Him007 is offline
Old 01-02-2007, 11:30 AM   #2 (permalink)
Kiran.dks's Avatar
Default Re: spyware issue
You can use freeware "SpyBot-Search & Destroy" or "Ad-aware" Antispyware software. Download it & scan entire PC in "safe mode"
Download: SpyBot
OR
Download: Ad-aware
Kiran Kumar R
Kiran.dks is offline
Old 01-02-2007, 11:33 AM   #3 (permalink)
I have Ad-aware in my PC, I scaned in the safe mode, not detecting any spyware.
I try to install the spybot, but while installation it says unable to register module .
tell me what to do?
thanks
Him007 is offline
Old 01-02-2007, 11:42 AM   #4 (permalink)
Kiran.dks's Avatar
Ok. Your Browser is Hijacked.
Download HijackThis to desktop
Run the program in the zip file
It will give a report
Copy & paste the report here for analysis.
Kiran Kumar R
Old 01-02-2007, 02:14 PM   #5 (permalink)
Yes I knw the browser is hacked, That's why want to get troubleshoot early.
__________
plz help me.......
Him007 is offline
Old 01-02-2007, 02:37 PM   #6 (permalink)
Kiran.dks's Avatar
Pl. post the HijackThis report here.
Kiran Kumar R
Old 01-02-2007, 02:42 PM   #7 (permalink)
ok I will post the report soon.
Him007 is offline
Old 01-02-2007, 04:06 PM   #8 (permalink)
same problem here....
Live Life King Size
Mangal Pandey is offline
Old 01-02-2007, 05:40 PM   #9 (permalink)
any solution u did MANGAL PANDAY...?
Him007 is offline
Old 01-02-2007, 07:15 PM   #10 (permalink)
nothing ...
i had started another thread the other day....
giving u the link..
may be u would find it useful.
Internet Explorer home page hacked & changed. how 2 restore it?
Live Life King Size
Old 01-02-2007, 07:32 PM   #11 (permalink)
I was having the same some days ago but after reinstalling Windows it get solved. Tell me if you cannot change your home page from registry. I have also tried HijackThis! when my browser gets hijack but it is of no use. If HijackThis! cannot do that then prost here and I will tell you a registry entry which you have to change to change your homepage.
abhijangda is offline
Old 02-02-2007, 07:16 PM   #12 (permalink)
Distinguished Member
anandk's Avatar
yes its a spyware attack. and ur browser/home/search pages have been hijacked.
first run adaware, avg, spybot (or any 2 good anti-spys) in SAFE MODE.
then use 'ccleaner' to clear up residual pc junk.
open your ie>intenet options>homepage>change to about:blank
then lock your home page.
If the feature is disabled (greyed out), go to Doug Knox's site and download this script this dougknox script and save this file to your hard drive. Navigate 2 where u saved it n double click d file. d VB Script file will check 4 d appropriate value & if not found will create it. u will be notified whether d option is enabled or disabled.
2 manually make d change:
open Regedit and go to and change to
[HKEY_CURRENT_USER\Software\Microsoft\Internet Explorer\Main] "about:blank"
Home Page Hijacked :
If the Tabs have been removed from Internet Explorer/Tools/Internet Options and/or u receive a restriction warning message, run
Restore All Tabs under Internet Options (kellyskorner tweak no 268 ) It will restore all tabs and lift the restriction.
after u have set to 'about:blank' using above or internet options now, lock it !
download this kellyskorner registry tweak and doubleclick/add 2 registry.
u will also check if ur hosts file has been hijacked.
its located in C:\WINDOWS\system32\drivers\etc
i suggest u download a GOOD hosts file from here http://www.mvps.org/winhelp2002/hosts.htm
unzip it and place it in the above location. replace ur existing file. dont worry !
read info in this link so that u r also satisfied. then LOCK ur hosts file.
quoted myself from What is happening to my computer?
> www.TheWindowsClub.com <
= www.WinVistaClub.com =
Microsoft® MVP
anandk is offline
Old 03-02-2007, 12:37 AM   #13 (permalink)
tell me one thing why ant-spware is not detecting any spyware in my machine in d safe mode?
spybot is not going to install it says " module error"
problem is still same.....
Him007 is offline
Old 03-02-2007, 01:13 AM   #14 (permalink)
coolsunny's Avatar
install avg anti-spyware 7.5. & then try. ur problem may be solved..
AMD X2 260, GA M68MT-S2P, Gskill RipjawsX 4GB, 500Gb Seagate, Cooler Master eXtreme Power Plus 600W, Altec Lancing atp3, Samsung B2230 TFT, Numeric Digital 600 EX-C UPS.
coolsunny is offline
Old 03-02-2007, 03:08 PM   #15 (permalink)
is it freeware?
Him007 is offline
Old 03-02-2007, 03:25 PM   #16 (permalink)
hailgautam's Avatar
yes avg is free.
Change is Nature, the part that we can influence; and it starts when we decide.
Where you going?
With Luck forward.
hailgautam is offline
Old 03-02-2007, 03:31 PM   #17 (permalink)
coolsunny's Avatar
no, u can try it for 30 days.& its better than spyboot
Old 03-02-2007, 03:42 PM   #18 (permalink)
Kiran.dks's Avatar
There are both versions of AVG Anti-Spyware. Free version is a cut off version of AVG paid version. Free version does not have real-time scanner.
Download Free version from here:
http://free.grisoft.com/doc/20/lng/us/tpl/v5
Onemore thing, Why can't you guys post the HijackThis report here. I am asking for the same from the beginning...
Kiran Kumar R
Old 03-02-2007, 03:58 PM   #19 (permalink)
GUNNING DOWN TEAMS
wizrulz's Avatar
i guess ur infected with SpySherrif adware.....
wizrulz is offline
Old 03-02-2007, 06:29 PM   #20 (permalink)
OK, I will try wd AVG anti spyware, let's see would it recover the problem or not?
Him007 is offline
- by gforz
